Techart Daytona wheel made by Speedline
I am in Thousand Oaks California. I am trying to locate a fellow Rennlister who lives close to me with a 996 Twin Turbo. I am going to build a set of wheels and want to test fit to custom size properly for the build. 805-498-7261
Thank you. Jim jdorociak@gmail.com
I have had the Daytonas, great wheel and lightweight as well...TUV approved.
The wheels specs ares good: aggressive
8.5x18" ET40
11x18" ET25
Only problem is I had to sell them cheaply because bigger brakes did not fit...
8.5x18" ET40
11x18" ET25
Did you have any fitment issues in the rear? They look awful close to the fender lip. I was thinking possibly using a 3.25" outer lip instead of the 3.75" that came on the set. I was going to use a slightly deeper inside rim to keep the size at 11". Thank you for your input - beautiful car. Jim
No problems, the stock wheels are 11x18" ET45 so the Daytonas come outwards 20mm more. That is much, but not too much, about the right amount I would say Especially with a lowered suspension the stock ones would be too much inside the fenders...
If you go for 315/30s or have rubbing problems then rolling fenders is an easy option.
Is there anyone else in the Thousand Oaks area? I really want to test fit as these wheels were 10" not 11" so the center is machined differently and I need to check before ordering new rear outer hoops. 805-498-7261 or 805-410-0727 cell. I live on Lynn RD. in Newbury Park CA, Jim
