996TT: 2 piece disc assemblies - GIRODISC Spring SPECIAL $1699 ALL 4 wheels
Former Vendor
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
No waiting. Ready to ship.
Full 4 wheel big brake setup for your 996TT.
Special is good only from May 1st through May 15th, no exceptions please.
SIZE:
Front: Factory 330 mm / GiroDisc 350 mm
Rear : Factory 330 mm / GiroDisc 350 mm
WEIGHT:
Front: Factory 24 lbs./GiroDisc 22.4 lbs. - slotted
Rear: Factory 20.5 lbs./GiroDisc 18.2 lbs. - slotted
Used by GT3 Grand Am teams
Preferred rotor setup of CarGraphic of Germany - German Porsche tuner
Up to 2X + the lifespan of OEM holed rotors
Option of slotted & drilled if desired - slotted is recommended.
Same price for either choice -
ALL hardware as well as the disc is FULLY PLATED to resist corrosion.
100% Made in the USA.
Call Craig at 425-765-1090 or e-mail rennstore@comcast.net for this exclusive price point.
This represents a significant $700 OFF the previous price
![](http://forums.pelicanparts.com/uploads14/DSC_0289+21240171296.jpg)
![](http://forums.pelicanparts.com/uploads14/DSC_02901240171311.jpg)
![](http://forums.pelicanparts.com/uploads14/DSC_0291+21240171326.jpg)
![](http://forums.pelicanparts.com/uploads14/DSC_0292+21240171338.jpg)
![](http://forums.pelicanparts.com/uploads14/DSC_0293+21240171362.jpg)
![](http://forums.pelicanparts.com/uploads14/DSC_0294+21240171377.jpg)
For ANY questions, call or e-mail Craig: 425-765-1090, rennstore@comcast.net
Thank You for your consideration. These represent a tremendous value on a top quality brake upgrade for your 996 Twin Turbo.
SIZE:
WEIGHT:
Former Vendor
Girodisc floating hardware:
Girodisc manufactures it's own floating drive bushes from a high strength steel alloy with a Rockwell C scale hardness of 26. These bushes have a stress relieving back-cut radius under the head to ensure maximum strength. They are cad plated to produce a brilliant corrosion resitant finish. The M5 socket head cap screws are grade 12.9 and are all assembled with locktite. The spring washers that control rattle are of a high temperature alloy that ensure rattle-free performance even after track days. The flat washers are from a hardened steel alloy. These components are used in all of our applications and are proven in the highest levels of competition.
![](http://www.girodisc.com/images/floating.jpg)
![](http://www.girodisc.com/images/spring-clip2.jpg)
Former Vendor
Just returned from out of town, I will scare up photos for the post -
They do indeed fit the 997TT.
Former Vendor
They are due to ship out to you TODAY ;-)
Typically 2 days to California, so I'll bet you have them in-hand Friday for a weekend installation.
