Quick Question for 2004 TT Owners
I recently added an iPod adapter to my car, and have noticed that when I remove the key and and exit the car (open and close the door), on the dash the clock, digital speedometer, and parts of the central display (odometer and trip meter) remain illuminated. When I use the remote to lock the doors and activate the alarm, they go out; otherwise, they stay on. I'm not sure if the car was doing this before I installed the iPod unit. Do your cars do this?
Thanks!
Thanks!
That is exactly what happens with the Dension iPod unit...actually it turns on when I unlock the door; don't even need to open it. My concern was a weak battery the morning after I installed the Dension Gateway. I do now know I better not forget to lock the door or the thing won't turn off, along with the dash display.
Just curious, how long did it take for you to install the Dension Gateway? Thanks.
--BM
The lights stay on for a good amount of time, but the manual says they are leds so they should have a pretty low draw. I figured something was wrong until I read the owners manual; somewhere buried in there it describes the lights staying on and for how long.
thanks
Thanks!
Thanks!
(BTW, as you can see from all the other replies, interior lights and dashboard illumination stay on for a period on after car is turned off and pop on when you open the door after the car has been turned off. Your car is acting normal!)
Super Moderator
Needs More Cowbell
Needs More Cowbell
the infotainment system is connected directly to battery
when the door is opened a CAN wakeup message is sent and the headunit powers up
some cars Cadillac for instance, use the sound system to produce chimes so it has to be designed this way
