Oil Pressure drops to zero then back up?
My Dad owns an 02 996 with the X50 package. He told me the oil pressure will drop to zero sporadically while driving then bounces back up. After some research, it sounds like the Oil Pressure Sensor is going bad. Can anyone confirm this before he purchases one?
Thanks,
Thomas
Thanks,
Thomas
Basic Sponsor
That is "normally" the fix for the problem you describe, unless you find it's a loose connection.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Professor of Pending Projects
From my thread:
Nov. 13, 2006 (51,814miles) - (1) Spoiler warning light comes on: Faults found 9150. Replaced spoiler motor/drive assembly - Part No. 996-512-241-02 (spoiler drive); (2)Failure Indicator error: Sender not showing correct oil pressure at times. Faults found 9121. Replaced oil pressure sender - Part No. 996-606-203-01
Thanks for the help. Can anyone provide a diagram or tell me where the sensor is located? Is it something that is easily accessible or is the car headed to my Dads mechanic?
Hi everyone, I'm bumping this ancient thread, as I'm experiencing this problem. Does anyone have a picture/diagram of the connection that I should be examining? I want to take a look before replacing any sensors/sending units.
The sender is a small chromated can behind the oil filter with two wires going to it, and a short hose that's attached near the oil cooler.
Lower your engine to get at it. Usually the wires on the top of it come loose. If you have to change it a crows foot wrench set is needed, just cheap from Harbor Freight is what I have.
I just replaced my sensor. My oil gauge was doing the same thing. Removal isn’t difficult. The challenge is reattaching the two leads back into the new sensor once installed. Only way I could do it was to unfasten the male connectors on the new sensor, attach them to the wire leads, install the sensor, then refasten the connectors to the sensor. Long nose pliers are a must. And patience. It’s a DIY.
911user (11-24-2020)
Lowering the engine an inch helps a lot.
Removing the oil filter adapter was the key to getting it out and back in when i did it, no crow foots required. My failure mode was that it read the same value at idle and when the engine was off, aprox 2 bar. swapped it out and now it reads zero engine off and 2 bar at idle.
