Are Bosch FR6 plugs pre-gapped
03-07-2008, 10:12 PM
Do I need to adjust the gap before installing FR6 plugs in a stock car?
03-07-2008, 10:19 PM
Yes, and as a rule if a spark plug comes with a plastic or cardboard sleeve in the packaging, its gapped.
03-07-2008, 10:24 PM
AddictRennlist Site Sponsor
Check them.... It only take a few seconds. I often find "pre-gapped" plugs grossly off.
03-07-2008, 10:25 PM
I just put a set of FR6's in. I checked each gap and found them to be within a thou. or two of spec and didn't need to make any adjustments.
M.
03-07-2008, 10:50 PM
Quote:
Originally Posted by
flankenspeil
Never knew that.
03-08-2008, 10:04 AM
How hard is it to change out the spark plugs in this car? Dealer wants $750.00 and says it takes 6 hours of labor.
03-08-2008, 12:29 PM
It took me near 6 hours 1st time through,,,,,,,,,,,,but I work for less than $125/hour after taxws.
M
03-08-2008, 01:26 PM
AddictRennlist Member Rennlist Site Sponsor
You can run the Bosch plugs out of the box. They are usually consistant. The electrode does have a protective sleeve like flankenspeil has mentioned.
If you are running larger turbochargers, you can tighten up the gap.
