996TT Handling
The 996tt does not have "sway" at high speeds, assuming the tires are appropriately inflated, fronts and rears have the same wear, and the suspension is properly alligned and undamaged. The tt doesn't "grip the road" less, it has some understeer on entry, but allows more throttle on exit. AS
Thank you all for the suggestions and advice. That was my suspicion all along. I'll ask the owner to get an alignment done after which I'll drive it and report on the difference or not.
