Scratch removal for headlights??
Professor of Pending Projects
I need to do some TLC to the 996TT...
Headlights are all full of hairline scratches... (ok, more like someone used sand paper on them... must be the almost 60k miles on it...) other that the expensive route of getting new ones... anyone here has been successful in polishing the scratches off the headlight?? If so, what product and process did you use. Do you have before and after photos? The more details, the better.
Thank you!!
PS-I will post photos this afternoon after I get home from work... so you can see what they look like today...
Thank you!!
Wachuko - I have 153,000 miles on mine and use the clear film - replaced it about a year ago as the film was pretty shot - what a difference - try putting the clear film on them to protect them from future damage. As far as polishing them - I think they are plastic lenses so be VERY careful. Good Luck!! T2
T2,
If I end up with new ones, absolutely... clear film would be the way to go.
I need to stop by the local autoshop and see what they have...
Thank you!
Thank you!
Be interesting if you posted a pic. I have used sometihng like this on non-P car lenses and it worked rather well:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
I use the Maguire's plastic polish on my boat and on the plastic window of my 930 cab....it's a very fine abrasive polish designed to remove scratches from plastic. Depending upon how deep the scratches and blemishes are will make a difference....if they're too deep, then that restoration kit that killerB referenced might work.....but it comes with a fitting for an electric drill....so you have to be careful about the speed. If you use that drill application, cover up your car because it's going to sling that polishing compound around.
I've never tried that restoration product....but because it's almost $40, I think I'd try the Maguires plastic polish first. It works well on the plastic windows on the boat and car....You might also try to do a Google search on plastic polish....there's undoubtedly something a bit cheaper out there.
Plastic Headlight Restoration
"This works real good but if the lens is sand pitted you need to hand sand the lens with 600 and 800 wet/dry sandpaper till the lens is smooth then use this kit to polish the lens out and will look better then new when your done [keep that sandpaper wet when you do this]" - Richard, Lemon Grove, CA
That is my situation...
I will remove the headlights from the car when I do this...
Yes. I just realized that I have it at home...same one I use for the rear window of the 964... I just need to do the sandpaper step first...
Burgled
WOW! After seeing the before last weekend at Daytona i cant believe they came out like new! How about PM or emailing what you did or better yet come over and do mine
How was the trip to the dealer for the 60K service?
