Wacky sunroof
My sunroof is acting up. When I press the auto close button, the roof closes most of the way and then reverses itself stopping half way open. This happens only some of the time. Other times it behaves normally. Any thoughts?
From Loren on RennTech.org (Thank you Loren!):
Teaching
1. With the ignition switched on, press the "lift" button and move the lifting/sliding roof drive to the "raised" limit position.
2. Press "lift" button again and keep depressed. After around 10 seconds, a complete cycle takes place from the "raised" limit position to the positions "lower - open - close".
3. Teaching of the characteristics has been completed after this process.
Note:
The "raise" button must not be released during the entire process. In the event of a restart, the lifting/sliding roof must always be moved to the raised limit position first.
4. If the lifting/sliding roof drive should move back in Item 1, then the closing force limitation function has responded (lifting/sliding force drive was taught). The "open" button must be re-taught in this case.
Re-Teaching
1. Press the "open" button until the sliding roof stops. Then release the button. Press again until the lifting/sliding roof drive stops again. Then release the button.
2. Press "open" button again and keep depressed. The entire process takes place after approx. 10 seconds: "close - lift - lower - open - close"
Teaching
Note:
Re-Teaching
I had this happen before, but it also made some noises like something was catching. P-dealer said the sunroof frame needed to be replace ~1k, then another 1k for labor! Ouch.... and no, I'm out of warranty.
I hope that reteaching the sunroof works out or you're still covered....
Did you have a creaking noise while driving prior to replacing the frame?
None. Just one time I was trying to close and it would just go back to the open position. So i held the close button and as it closed, I heard a crack/bang noise as it shut. After that, it wouldn't close without me pushing the sunroof up....
thanks.
Teaching
Note:
Re-Teaching
Teaching
Note:
Re-Teaching
probaly a weak motor, open the sun roof and clean out the track, apply some lube to the track. and run the motor a few times.
I would say to try replacing the motor then re teaching it after. YOu can change the motor your self in probaly a half hour or so
I have noise problem from the sunroof. I ' ve found out that the noise is coming from the plastic on each sides. I think this plastic prevent airflow coming in from sides when roof is tilted .
When roof is tilted there is NO noise but then the plastic is tight .
Is it possible to disconnect this part? I never use the sunroof so for me it could be welded.
