Clutch Question - How easy should it be to depress?
Hard to describe BUT ..... I have an 02 turbo. The clutch is easier to depress than on my previous 996 but I drove an 02 TT (before I bought my existing one) and there was almost no effort to depress the clutuch pedal.
Any feedback on how easy the hydrolic clutch should be to depress? Thx
I had the same feeling of difference between my previous 2001 C4 and the 2001 TT the clutch is A LOT easier to depress on the TT.
One thing also that seems to be re-occuring is that their is a lot of diagnostic of bad clutch that are only the accumulator.
I had a PPI done on the 27k miles TT I got. The Porsche Dealer called for a replacement of the clutch for $4k and also change the accumulator... I negotiated with the seller regarding the clutch condition, after driving the car and made a deal to take it like that with the intention of having the clutch changed myslef instead of the dealer.
The clutch felt a little weired but worked fine, after searching the various boards I decided to change the accumulator first for $110/part and about $150/labor before jumping into a clutch job... Also I found strange that a car with 27k miles with one small Stage 1 over-rev when the car had 5 hours and no stage 2 over-rev (meaning to me the car was not tracked) would need a clutch...
Sure enough the clutch has worked fine with the new Accumulator and feels a lot lighter than the C4.
Hope this helps,
G.L.
Part reference:
http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
Hope this helps,
G.L.
Part reference:
Always was ......waaaaay too much power-assist dialed in on the 996TT clutch (IMHO)....and many would say too much travel also.
When she came out, there were many comments.
I can not speak for current Turbo but between 993,986,996, Caymen and 997, the 996TT has the lightest clutch..........you get used to it. But for me it's more of a 'challenge' on the track.
