Year differences
Year differences
Question for the board, since a search failed to give me everything I needed. When purchasing a 996tt, is there anything significant between any of the years that one should be aware of. All the research Ive done has yeilded that output figures have been constant, and I haven't found any engineering upgrades at all. Any input here at all?
Second, living the the Northeast, when is the best time to buy a 996tt? I would assume the cold months, but not sure if that is even a factor.
Thx in advance.
Thx in advance.
As far as I know nothing changed @ all on the 996 TT w\ the exception of the stereo, which went to a Bose system in '02. What time of the year to make your purchase.......I don't think it matters one bit, Maybe for a cab it would be a diff. story.
'04 have the new engine case. Stronger bottom girdle-reinforced webs. However, the stock 996TT which is based on the 964 casting is strong and does not have any issues.
Technical Guru
goto the Porsche Techinfo site and select the country Sweden, then click Training Documents and from there you can select different Porsche models (911, Turbo, Boxster, Cayenne, GT) and you'll get list of Adobe .pdf files for each model year showing the differences from the year previous.
