The Correct Way To Convert RWHP/AWHP to FWHP
Rennlist Lifetime Member
Originally Posted by Jean
FWHP= RWHP/0.85 (or whatever)
Originally Posted by PorschePhD
Correct. You know the answer to the question that is the RWHP. You need to know what the original question was. Just like in HS Algebra. The simplest of the equations. You need to back out of the answer, hence the /.87 or /.75 or whatever loss your car is putting down.
Not sure. I haven't looked on there in a while. I forget and lurk the 997TT and 996TT boards there.
No worries, lots of confusion on loss numbers.
We know your car has about 500 FWHP and that's plenty enough.
Originally Posted by Dock
The 500 number may be accurate; however, I'd bet it was much higher than that on the 128 mph trap speed run.
Just pulled the front driveshaft for tomorrows dyno runs... surprisingly easy. 35 minutes start to finish. 6 15mm on the trans support and 3 15mm on the shaft... slide it forward and down and pull the splined shaft out. The body panels were the biggest pain. Taking the wife out to dinner tonight with my new GT2 and its pouring rain here.... should make for an interesting drive. Kevin
Kevin, just insert your low boost program.. Right.. But you can't
Just a thought, why don't you hold off on the Dyno run till you have your new program installed???
Originally Posted by KPG
I would prefer to have the most inflated numbers possible so Jean and TB have something to complain about.
Kevin
Originally Posted by 9Eleven
You won't be alone. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
They would not know what to do without us. Pssst.... dont tell anyone.... but I am going to take out my spare tire during my runs.... worth 30HP crank.... SHHHH.... just between us. Kevin
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
