996 Turbo Forum 1999-2005
Engine of GT2 versus X 50
Old 11-29-2002, 06:07 PM
Ralph K
4th Gear
Ralph K's Avatar
Post Engine of GT2 versus X 50
Greetings:
1st post
I am a new member. Just purchased a
"stripped" 03 BLK/BLK X50 with the C-brakes.
I have never had a Porsche before. I am
an enthusiast for speed though. I have
a 2000 Suzuki Hayabusa Motorcycle.
January 03 delivery. Question I had
was what are the differences between the
GT-2 and X-50 TT engine? I know what the
factory ratings are. I am just curious how
the internals of the engine and accessories
are different.
Thanks for dropping by.
Ralph
Old 11-30-2002, 12:53 AM
ag
ag's Avatar
Post
Ralph-
As far as the engine goes, the difference is 0.1 bar peak boost, otherwise no difference whatsoever.
Old 11-30-2002, 05:11 AM
kenratboy
kenratboy's Avatar
Post
Give it .2 bar of boost and tell all the GT2 owners to...
Old 11-30-2002, 05:19 AM
FixedWing
FixedWing's Avatar
Post
There is some debate about whether there are any internal differences between the two engines. If there are, they are small differences.
Have you researched the PCCB brakes? You might want to do a search here.
S.
Old 11-30-2002, 09:16 PM
cosmos
cosmos's Avatar
Received 1,205 Likes on 657 Posts
Post
Fixed:
I cancelled my PCCB brakes and got the X50 option instead.
Can't wait for 380mm 8 piston Brembos.
Old 11-30-2002, 09:28 PM
Oak
Oak's Avatar
Post
The 8 piston Brembos are now available, but you need to run 19" wheels. The calipers will not clear on 18" wheels.
The GT2 steel brakes are a great alternative, this is how the GT3 cup cars are now equiped. I have upgraded to the GT2 steels and am very happy with this set up. I would highly recommend this upgrade.
Old 11-30-2002, 09:35 PM
GlobeTrotter
GlobeTrotter's Avatar
Post
I thought standard Porsche brakes were first rate. Superior to Brembo, b/c Porsche manufactures their brakes themselves. I know for sure that it's the Porsche rotors that are the best, does Porsche outsource their Calipers? Could you clarify this?
[quote]Originally posted by cosmos:
<strong>Fixed:
Can't wait for 380mm 8 piston Brembos.</strong><hr></blockquote>
Old 11-30-2002, 09:41 PM
Oak
Oak's Avatar
Post
The calipers are made by Brembo to Porsche specs.
Old 12-09-2002, 11:17 PM
DKC
2nd Gear
DKC's Avatar
Post
I have a GT2 and even though there is little HP dif there is a tremendous jolt dif between the x50 because the torque is applied to the rear wheels only. I would suggest Brembo 4 piston over the ceramic brakes. The ceramic are made for the track to cover overheating. The Brembos are great for day to day.
Old 06-15-2004, 10:04 AM
996racer
996racer's Avatar
Fixed:
Did you get your 380 mm brakes yet? Do they require going to a 19" wheel?
Old 06-15-2004, 12:00 PM
msindi
msindi's Avatar
racer - Check your other post
Old 06-15-2004, 07:52 PM
Darius Juca
Darius Juca's Avatar
Do you guy know what your 1/4 mile times are? I wonder how I would do against a X50 or GT2/3....You guys have awesome cars!!!!
Old 06-18-2004, 04:16 AM
technik99
7th Gear
technik99's Avatar
Aren't all "GT" designated Porsche engines based off the GT1 engine? If so, then the differences between the GT2 engine and regular 996TT engine is more than just boost.
Old 06-18-2004, 10:12 AM
996racer
996racer's Avatar
I think you are confused Technik, all 996 water cooled motors are based on technology found in the GT1, the GT2 is the turbo evolution of that GT1 based street motor and the GT3 is the NA evolution of the GT1 based street motor.
Old 06-18-2004, 11:52 AM
Steve in FL
Steve in FL's Avatar
996racer: I think you mean all variants of the 996 Turbo water cooled motors and the GT3 motor are based on technology found in the GT1. That does not apply to the standard 996 Carrera 2 and Carrera 4 motors.
Quick Reply: Engine of GT2 versus X 50
