AFR gauge install
Basic Sponsor
AFR gauge install
Could someone explain how to connect an AFR gauge on an '02 996TT? Is there a brand that has a similar look and back lighting to the stock aluminum gauges and works well? What about mounting options - I would appreciate any input and pictures of installs.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Ok have to admit I'm getting one too. But has anyone considered the difference between the 5bar and the one that "kinda" adjusts itself?
PS install for me is easy............go to dealer with part and ask to put said part in!!!!!
Basic Sponsor
Tom,
I think you are referring to the FPR (fuel pressure regulator) and my original post was about an AFR gauge (air/fuel ratio). My understanding is that they are tapped into the 02 sensor wiring above the quick disconnect, but I am not certain. If that is all it is, I would like to attempt to add one. If it requires drilling an additional bung, then there are more issues such as where to drill the hole, etc. I was hoping someone with experience would comment.
I don't know how to install an AFR gauge, but I do know you should get a wide band gauge in order to ensure accuracy. Many of the popular AFR gauges are not wide-band. I use the AEM gauge:
Craig
Craig
Good looking gauge Craig. I would like to get something like that mounted up on the steering column so I can keep an eye on it. Would be REAL nice to have a REAL boost gauge mounted there also - preferably built into the same gauge.
Craig
Craig
Jag
Originally Posted by jags911tt
Craig on the fabspeed cats there is an extra hole for an O2 sensor. Can I use that gauge and the sensor would plug into that hole?
Jag
Jag
Craig
http://www.innovatemotorsports.com/ makes several good units that use the lsu4 sensor. Datalogging is also an option that is interesting. As to installation have a bung welded in before the cats and downstream of the turbos. That way you can keep the std sensors in place.
