996 Turbo Forum 1999-2005
BEDDING IN BRAKES..DO YOU..AND HOW???
Old 12-02-2005 | 01:13 AM
tkerrmd's Avatar
tkerrmd
Question BEDDING IN BRAKES..DO YOU..AND HOW???
BEDDING IN THE BRAKE PADS....DO YA....AND HOW??
Going to Pagid orange pads for my next 2 day event. Reading on there site re "bedding in" process. Is this what you guys do or something different or is it old school urban legend??
TIA
tom
Old 12-02-2005 | 01:33 AM
JPschnitzer's Avatar
JPschnitzer
OK Tom...This is important. I have learned this lesson enough times for all of us. 1) You def. want to bed your Pagid Oranges properly....2) If you don't, your stering wheel will be juddering in your hand for the whole track day and you will hate it. 3) Bedding these suckers is not easy and it requires some finnesse 4) Even if you try to properly bed them, you still might end up with uneven pad deposition and a judder in the steering.
You need to do about 10-15 rolling stops. Get the car up to about 70-80 gently apply brakes with a consistent brake force....slow down to 5 mph and ease off......immediately repeat the process. This should do it.....
Also, when you take the track....gently warm them up....Do not jam on the brakes the first few laps.....
You are essentially applying a thin even film of brake pad material onto the rotors....If you just jump on the track and start lapping hard, you will be very unhappy with the results.
Good luck....Be safe....
Old 12-02-2005 | 02:50 AM
supercup's Avatar
supercup
Tom,
Check out this information www.stoptech.com, they have a bunch of good information on bedding in brakes etc... Look under technical and then under white papers.
JCM
Old 12-02-2005 | 03:34 AM
Bob Rouleau's Avatar
Bob Rouleau
Still plays with cars.
Tom - read the info on the stoptech web site and follow the directions. I'd also suggest you try the Pagid RS 19 Yellow endurance racing pads - a big improvement over the Orange. The RS 19 makes less dust and is very rotor friendly which the orange is not.
Best,
Old 12-02-2005 | 04:27 PM
Gator_86_951's Avatar
Gator_86_951
Spell Checker
Tom are you going to the January 29th event? Or is this something earlier. We are doing rennstock here in town and I should be doing the 29th event with suncoast of a very long and horrible 1 year break from track days.
Old 12-02-2005 | 05:01 PM
Mike/A.W.E.'s Avatar
Mike/A.W.E.
user
TIA
tom
Check out this link. It's right from Pagid's web site.
http://www.braketechnology.com/brakepadbedding.html
Old 12-02-2005 | 09:28 PM
tkerrmd's Avatar
tkerrmd
Wow!!!! Great help, just what I needed, really appreciate all the info and responses....love this forum!!
PS.....Gator.....I'm going to PBOC at Homestead Dec 9 and 10th!!! Still looking for ya!!
tom
Old 12-02-2005 | 10:04 PM
T2's Avatar
T2
I have the Gen 1 PCCB's with 78,000 miles on them - original rotors and second set of pads - yes bed them as JP indicates above and always always at each heat spend 3-4 laps warming the tires and progressively heating the brakes as well as cooling them properly after a hard heat or run in the car.....this has worked for me for the miles above on PCCB's - which I swear by over the stock turbo setup - and yes I have about 25,000 miles in another Turbo in the stock brake setup
Old 12-30-2005 | 10:06 PM
BertBeagle's Avatar
BertBeagle
You could not worry about it and send your pads to these guys - www.prosystembrakes.com
They pretty much wrote the book on dyno prebeding of brake pads and rotors years ago and have done thousands of pads and rotors. Quick turn around also.
Old 12-31-2005 | 12:09 AM
tkerrmd's Avatar
tkerrmd
thanks for the info Bert
Old 12-31-2005 | 01:31 AM
rbcsaver's Avatar
rbcsaver
As others said, follow the letter of the Pagid procedure as outlined on their website and review the stoptech site too. Very important, as I learned from experience.
regards,
Steve
Old 12-31-2005 | 01:35 AM
tkerrmd's Avatar
tkerrmd
thanks Steve!!
Old 12-31-2005 | 09:59 AM
m3bs's Avatar
m3bs
Any idea what the cost is for the "Pre-Bedding" service? I've found it nearly impossible to properly bed pads on the street, and on the track the drivers behind don't seem to appreciate all of those rolling stops (what a surprise).
Quick Reply: BEDDING IN BRAKES..DO YOU..AND HOW???
