996 Turbo Forum 1999-2005
SPARK PLUGS DIY QUESTION
Old 10-12-2005, 07:58 PM
billystang993
billystang993's Avatar
Lightbulb SPARK PLUGS DIY QUESTION
Anyone knows if its easy to replace the spark plugs?
anyone with DIY
i changed ones on my 993 im wondering if its harder than that.
Old 10-12-2005, 09:56 PM
PorscheDoc
PorscheDoc's Avatar
On the twin turbo, you have to remove the bumper cover, part of the fender liner (just the rear section), then the intercoolers and heat shields, then you can get to the plugs. Pretty easy, but have someone help you get the rear bumper cover off if you like your paint. The NA is much easier. Should take you a couple hours. If you need a DIY, PM me i can guide you through it.
Old 10-13-2005, 12:54 AM
Dock
Dock's Avatar
It took me about three hours the first time I change my plugs. After doing it a few times I'm down under two hours now.
If you have big hands, it's a tougher job.
Old 10-13-2005, 02:13 AM
sharkster
sharkster's Avatar
Yeah I just take the exhaust off, the inner fender liner, the heat shield and then do the plugs that way. Kinda bad for big hands...
Old 10-13-2005, 10:29 AM
billystang993
i will have my wife do it!!
ha,ha!!!
thank you guys!
someone said i have to take the bumper out.
i guess not
Thanks again and thanks Alex for your xtra help!
Old 10-13-2005, 10:52 AM
PorschePhD
Rennlist Lifetime Member
PorschePhD's Avatar
It is faster to pull the bumper then the stock exhaust.
Old 10-13-2005, 11:40 AM
viperbob
Former Vendor
viperbob's Avatar
That must be easy to do on your car Alex as your exhaust is generally off anyway
Old 10-13-2005, 12:08 PM
Woodster
Woodster's Avatar
I am going to try mine tonight, I got a print out from the dealer and was even more confused???
Confusion was due to the fact the dealer papers says to remove rear "spoiler" first.
The rear "spoiler" is what most of us call the bumper! LOL. Any special tools needed,
like to undo any clamps? please advise if you know. I think I will remove rear bumper method.
How about the heat shield, can it be removed without bending it? I heard that is the challenging
part. Oh, the dealer said 7 hours!!! LOL.
Marty
Old 10-13-2005, 12:33 PM
sharkster
sharkster's Avatar
Hehe it sure is easier.. the other unique thing about my car is I don't even have to take the inner fender liners out since my 335's burned a nice access hole straight through so I can get my arm into where the coil pack is lol!
How you been pal? How's Florida treating you????!
Old 10-13-2005, 12:34 PM
sharkster
sharkster's Avatar
Yeah but then you were saying the ICs have to come off and so on... Dunno, I like doing the exhaust way... As long as you have a lift that is....
Old 10-13-2005, 02:35 PM
PorschePhD
PorschePhD's Avatar
Nah, 5 bolts and simply pull the clips. Takes 2 minutes to pull one intercooler. Just don't bind the hose and you are good to go. Pulls right out.
Old 10-13-2005, 02:39 PM
sharkster
sharkster's Avatar
Yeah but if you do it my way you get to check and see just how blue your hot-sides are and if you've been a good boy and not done any hot shut downs lol!
Old 10-13-2005, 05:36 PM
JeroenVdb
6th Gear
JeroenVdb's Avatar
Thanks guys , great info !
Old 10-13-2005, 05:58 PM
PorscheDoc
PorscheDoc's Avatar
I will post a write up sometime tonight with some pics of how i do it. It will be off the top of my head, but i can get pretty close.
Old 10-13-2005, 09:18 PM
PorscheDoc
PorscheDoc's Avatar
Ok, here is a quick write-up i did from memory. It isn't perfect yet, but will give enough of an idea of how to do the job. Next time i do some plugs, i will take good pictures and make sure everything is exact. I didnt bother resizing pictures or anything so the file is about 1.68 megs and is a word doc, so it will take a minute to load. Anyone can feel free to pop in with additions and i will make the changes. If anyone has some pictures of the intercoolers on the car, i will add that, as it will show some bolt locations. Anyhow, supper is on, hope this helps out a little....and no i didn't spell check it yet....
996 Twin Turbo Spark Plug Replacement Writeup
Quick Reply: SPARK PLUGS DIY QUESTION
