Problems with Oil...I think i overfilled her!
Well, yesterday whilst backing out of my driveway slopem i got a low oil message. I got the car to level ground...checked it and had 1 bar of oil. I checked it like 10 more times as it was delivered w/ 3 bars. So i go to target get some mobil 1 and figured 2 qts would be plenty.
Check the oil again....all maxxed out!!
I checked it several more times...same thing. I guess, they've got no scale on that measure, but surely, 2 qts on a "low dipstick" shouldnt be too much.
Anyhow, what do i do?
Is it easy to remove excess oil?
2 qts is a lot!!! usually the digital mter in the dash is only the top part of your oil tank no the whole thing....If I remeber it used to only take me 1 qt + 1/4 to fill up the whole dash gauge from flashing empty to full
There are 2 easy ways to drop the oil.. You can pull the drain plug on your engine.. If you have time, you can crack it open and let it dribble out, without taking the entire plug out.. If you take the plug out, you will drain 3 quarts++
You can also drain your turbocharger sump tanks..
okay...so whats the easiest way to do either of those two things?
especially for a pcar noob?
is this worth a 30 mile trip to the dealer?
or is this a jiffielube issue?
should i not drive the car?
I wouldn't risk a high oil level.. Do you have tools? This might be the time that you call your local Porsche friend that changes his oil to help you out.. Beer and Pizza supplied by you..
It's prolly not a great idea to drive the car. R-D-R above has prolly given the best advice. Make sure hose is clean, strong enough to not break off, narrow enough, and if it isn't easy drain from the turbo sump.
I don't recommend sticking a hose down the oil filler neck.. It isn't a straight pass, if it gets caught any plastic that gets shaved off your tube from the metal collar inside the neck, goes right into your sump tank...
