996 Turbo Forum 1999-2005
2003 X50 2nd gear popping out
Old 01-14-2005, 03:17 PM
SLVRX50
SLVRX50's Avatar
Default 2003 X50 2nd gear popping out
Every so often when coasting in 2nd gear, it will just pop out of gear. Took it to the dealer and they couldn't simulate. I've read on roadfly that someone else had a similar problem and the dealer replaced the tranny. Is this common and have anyone heard or experience anything similar. I just bought the car used about 2 weeks ago with only 5K miles - had the dealer inspect it before I bought it and it checked out fine. Thanks for any advice or comments!
Old 01-14-2005, 04:36 PM
Greg A
Greg A's Avatar
If you do a search, you should be able to find several people on here who have had that problem. It is a known issue on the earlier cars, but I thought it had been fixed.
Find a hill near the dealer and let off the gas while going uphill in 2nd gear. I think that will cause the tranny to pop out of gear.
Sounds like your dealer's service dept. needs some help. Do you have a different dealer in your general vicinity?
Greg A
Old 01-14-2005, 04:43 PM
SLVRX50
SLVRX50's Avatar
Greg,
Thanks for the info - will try what you've said. It doesn't pop out all the time just when I'm coasting - I've noticed when I'm coasting on flat or even a small decline. Who knows!
I took it to Neport Beach Porsche dealer - they are cool about it and belive me, but they couldn't simulate it - I've only had the car for about 2 weeks and it has happened about 4-5 times.
Old 01-14-2005, 06:26 PM
nash
nash's Avatar
This is definitely a known issue and somewhat common amongst X50 cars (at least).
Old 01-15-2005, 12:13 AM
thusly
thusly's Avatar
Default 2nd gear
FWIW - I had heard that the steel synchros with the X50 and GT-2s need to be brought up to operating temperature before efficient and effective usage; if they aren't, premature wear occurs causing gears to pop out.
Old 01-15-2005, 01:00 AM
PTEC
PTEC's Avatar
Bummer it didnt happen when your car was in for service, it probably just didnt actu up for the technician. Unfortunately they dont get paid to drive your car around all day trying to duplicate a problem that might or might not be be there. The fact that it didnt happen while it was in doesnt have anything to do with the competence of the technician.
Luckily you're still under warranty and will be for quite a while. If you can try and identify commonalities of when it pops out of gear and relay them to your service advisor at your next visit. Which ever technician gets your car should want to replace the transmission, its a job they will make a little bit of money on, though they dont want to replace a transmission that has nothing wrong with it, as thier dealership will get charged back for the transmission and their butt will get reamed severlely.
Old 01-15-2005, 01:35 AM
SLVRX50
SLVRX50's Avatar
Thanks for the help everyone.....drove the crap out of it today (finally a nice day in so cal - been raining for the past 2-3 weeks - boy are we spoiled out here). Didn't pop out today at all - will keep a close eye on it however.
Much thanks!
SLVRX50
Old 01-15-2005, 06:33 PM
msindi
msindi's Avatar
Had this when I had under 300 miles on my X50 - fix is a new tranny....should be under warranty
good luck
Old 01-15-2005, 08:22 PM
omega
omega's Avatar
just a reg 996tt same prob only few times maybe 4 in 2000 miles , changed to b&m it still pops out can feel it go all the way into gear so I doubt it's the linkage or the shifter dealer thought it was the cable clips , however I checked then out and they seem fine . glad to hear I'm not the only one goooood luck . STEVE
Old 01-15-2005, 09:38 PM
Turbo Ron
Turbo Ron's Avatar
It will get worse in time. Bring it back to the dealer at that time. Mine took about 3 weeks to pop out more often. The dealer replaced my transmission at that time. No problems since.
Old 01-16-2005, 01:28 AM
JS
JS's Avatar
You need a new tranny, that will be the fix.
Old 01-17-2005, 08:26 PM
Darren911
Darren911's Avatar
yep - had the same prob and no fix would take so my dealer got me a new tranny under warranty - all fixed now
Old 01-17-2005, 10:31 PM
SLVRX50
SLVRX50's Avatar
Thanks for all the responses – drove it to the LA auto show on Sunday and it pop out 2 separate times again. Taking it back to the dealer next week (to have the CD player fixed – was waiting on parts) will demand a new tranny then. Sounds like a common issue with the X50.
So, when I get the new tranny installed – will I need to warm up the tranny before my other personality (Michael Schumacher) kicks in?
Thanks!
SLVRX50
Old 01-17-2005, 11:05 PM
BoneDaddy
BoneDaddy's Avatar
This isn 't just an X50 problem. My 2002tt has done it about 6 or 7 times in the last 6 months, with around 14k on the odo. I guess I'm heading back to the dealer as well...
Old 01-18-2005, 09:51 AM
Darren911
Darren911's Avatar
Guys demand a new tranny - Porsche knows of this problem and will replace the tranny - just demand it from your dealer...there is no fix for this besides a new tranny
Quick Reply: 2003 X50 2nd gear popping out
