996 Turbo Forum 1999-2005
Need help with disgnosing a sound
Old 05-16-2023, 11:20 AM
misterted
misterted's Avatar
Default Need help with disgnosing a sound
When I drove locally around town I get a high pitched squeal coming from what sounds like the engine compartment over my right ear.
Car must be at temperature.
Only happens once I'm driving and going through the gears
When I stop at a light the sound remains consistent until I depress the clutch, that makes it stop immediately. Nothing else makes it stop.
It's not so high pitched like a loose fan belt squeal,
It doesn't happen consistently but does happen more often than not.
Hope someone has had this experience and can point me in the right direction.
Thank You.
Old 05-16-2023, 01:13 PM
2fcknfst
2fcknfst's Avatar
Received 3,916 Likes on 2,976 Posts
Throw out bearing on the clutch perhaps?
Old 05-16-2023, 06:20 PM
Lazurus
Lazurus's Avatar
Hi,
I am "new" here but not new to Porsche.Your problem is a long known issue described by Porsche in TSB 4897. The "valve" in your power steering reservoir is oscillating and creating the "whine" described as being reminiscent of a "tea kettle whistle". Replace the steering reservoir and the issue will be gone. "Most" long time early owners have long since dealt with this issue. Or else live with it and as you say "depress the clutch" to mitigate the noise.
It only happens when engine temperatures are high.
Carlo_Carrera (05-16-2023)
Old 05-16-2023, 06:37 PM
wross996tt
wross996tt's Avatar
Yep, power steering reservoir.
Old 05-16-2023, 07:13 PM
misterted
misterted's Avatar
Originally Posted by Lazurus
Hi,
God I love these forums, I was racking my brain with this.
Thank you.
Old 05-16-2023, 07:15 PM
misterted
misterted's Avatar
Hi,
Would you happen to know how many hours of labor this would fall under?
Thanks again.
Old 05-16-2023, 07:50 PM
Lazurus
Lazurus's Avatar
Thanks again.
I'm sorry as I can't recall labor hours as my replacement of it was covered under the original factory warranty. Thanks to the Porsche service bulletin.
But you are welcome, and I can assure you that this indeed is your issue.
Old 05-16-2023, 08:28 PM
TexSquirrel
TexSquirrel's Avatar
Received 2,392 Likes on 1,269 Posts
7.9 hours
Old 05-16-2023, 09:04 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,322 Likes on 1,480 Posts
Originally Posted by TexSquirrel
7.9 hours
LOL, no it's just a couple of hours.
I believe someone here just recently fixed this by replaced the just the top portion of the pump which the noisy valve is a part of. That made the fix super quick.
Old 05-16-2023, 09:26 PM
TexSquirrel
7.9 hours is the book time for R&R the power steering pump.
Old 05-16-2023, 09:37 PM
Carlo_Carrera
That maybe what the book says but it doesn't take anywhere near that amount of time. The pump it right on the top of the engine.
Old 05-16-2023, 10:08 PM
TexSquirrel
Yeah, book time is often higher than actual time.
As a flat rate mechanic, that’s what you hope for.
Expect to pay book time if you take it somewhere.
Expect it to take book time the first time or two that you do it.
Old 05-16-2023, 10:42 PM
Carlo_Carrera
..Expect it to take book time the first time or two that you do it.
Nah. A couple of hours. Less if you just replace the top portion.
https://rennlist.com/forums/996-turb...servoir-2.html
Old 05-18-2023, 10:53 AM
misterted
misterted's Avatar
This is very helpful, thank you.
Old 05-26-2023, 04:10 PM
Yogibara
Yogibara's Avatar
Do it yourself. It's not hard. My TT has a 997 PS reservoir to address this issue. While I don't personally have a video on this topic, I've found many that discuss this top on YT. Good luck!
Quick Reply: Need help with disgnosing a sound
