996CTSR race build....
#92
#93
That is very cool; pity they are not street legal as they are most certainly brighter than stock.
And there is nothing wrong with an 8800lm light with that filter on it; very impressive. I used two of them (not that model, drive/flood) on my Excursion and they are very very good at identifying caribou and deer lurking in the ditches on the side of the road.
As it is now a pure race car, do you even need lights up front? Sounds like a little more weight savings potential if you don't.
#94
#95
With the said, I have a mint condition set of OEM Xenon light assemblies for sale now...
rathersmart (06-23-2022)
#98
Engine has been in and out of the car a few times getting all the various details sorted and for basic engine runs. Base Motec tune is done with the rest to be tweaked on the dyno. I stopped by the shop and did the last engine drop yesterday so that final fitment off all the various accessories can be finalized. Since the engine has been severely simplified, dropping it out of the car is roughly a 90 minute affair start to finish. Disconnect Y-pipe, Drain coolant, disconnect driveshafts, 5 coolant hoses, 2 clutch lines, 1 fuel line, shifter cables, harness connector, and unbolt the gearbox and engine mount nuts. That's it. Here are some pics some of you technical engine types may find interesting...
Tial XR1000 turbocharger with deleted breather line.. Note the water cooling return line.
Left side bank fuel rail.. Note the capped-off supply port which is no longer used. Fuel enters the fuel rail via the fuel line between the 2/3 intake runner.
Right side bank fuel rail.. Note the absence of a fuel pressure regulator. Fuel enters the fuel rail via the fuel line between the 4/5 intake runner.
-8AN fuel supply line feeding the engine through 3 fuel dampers. The 3rd fuel damper is visible mounted on a bracket next to the #3 intake runner. Note the left bank N75 valve above the duel damper. Right bank has it's own N75 valve.
Close up of the fuel damper. Note the crankcase pressure line ahead of the oil cooler and it's associated line going to the pressure sensor.
Water heater line capped off on the engine Cup style, visible between intake runner 1 and 2.
Gill oil level sensor. These are the sensors used on F1 cars. Very precise...
-4AN wastegate lines. Note the capped-off turbocharger breather lines.
IPD 75mm intake plenum. Note the only port on top of the plenum is for the -3AN vacuum/boost reference line for the fuel pressure regulator located in the front trunk by the fuel tank.
Motec LTCD (Lambda to CAN dual) module along with the intake plenum boost pressure sensor located under the Y-pipe (where the A/C compressor would normally reside).
Left 1-3 bank and right 4-6 bank connector for the turbine drive pressure sensors. Note the aluminum "Y" splitter for the -8AN fuel lines going to each respective fuel rail.
Left bank stainless steel exhaust with it's V-banded 3.5" titanium straight pipes and associated Ti 1/4 wave resonators. Only 1 newer generation Bosch LSU 4.9 oxygen sensor per bank. Note the 997GT3 vacuum pump located on the drivers side intake camshaft.
997Cup serpentine belt routing. Note the 997Cup idler pulley (one with holes) and the associated light weight Cup crank pulley.
Gearbox with it's oil cooler and accessories visible. Top to bottom, note the disconnect line for the clutch hydraulic bearing supply, vacuum/boost reference, clutch hydraulic bearing return. The blue silicone coupler is for the cold side coolant inlet for the gearbox cooler. Vacuum operated coolant valve is programmed to open when vehicle is moving and gearbox temp is above a preset temperature
-8AN fuel line disconnect ahead of the gearbox bolts up to the 2nd fuel damper located in the tunnel (1st fuel damper is by the fuel tank in the trunk). The fuel dampers are a key (but completely overlooked by most) to a smooth running engine with big injectors. The hot coolant from the gearbox cooler outlet connects to the hot side coolant pipe in the passenger side of the car.
Solid metal hard transmission mount
Capt. Obvious (07-06-2022)
#102
Awesome info as usual. @powdrhound can you explain the engineering/design behind deleting the breather tubing at the turbochargers? Do the turbo oil tanks just not need this system anymore with the Xonas? Would love to simplify as much on my setup as I can while I have the engine out.
Am I correct that these deleted hoses originally had vacuum to help gather oil vapors back to the sump tank (vacuum provided by the larger hose on the side of the sump tank plumbed into the intake plenum pre-turbo)?
#103
#105
A couple questions about the vacuum setup here:
- Are you still running the venturi for the brake booster? I know the OEM setup has it connected here.
- I believe the #16 check valve looks to be gone and the associated fuel tank EVAP valve. Deleted since it's a race car I'm assuming? Do you just have the tank vented to atmosphere?
Love the simplicity!
