...Where are you taking yours for an alignment out of curiousity? Planning to align mine myself, but would love to know who you trust in ATX.
I'll have TPWS: https://www.tpwsinc.com/ set up the the corner balancing and alignment once all my parts are in since they'll do the install but I'm still about 3 months out.
@lost27 running very similar setup - its really night and day difference compared to stock setup. I have zero complaints of the components selection one year out from install.
Good luck
Thanks! Glad to hear you're enjoying the set up. I'll be coming from FVD spec PSS9s to this new set up so I can't wait. If you don't mind do you mind sharing your settings for the coilovers and swaybars?
sure I’m running 12 clicks front and rear on the ohlins
not too specific and off top of head on rest front sway bar is kinda limited but closer to softest setting based on fittment and rear I have in middle
Allignment wise in around -2.1/-2.6 Camber and toe around zero .
I can be more specific but I need to find some paperwork or visually inspect.
Since all these parts are about to get installed next week, I figured I'd go ahead and weigh them for future reference:
DemonSpeed Front Adjustable Toe Links (Pinch Style): 919 g | 2.03 lbs
DemonSpeed Rear Adjustable Toe Links (Pinch Style): 1540 g | 3.40 lbs
DemonSpeed Rear Toe Locking Plates: 449 g | 0.99 lbs
Ohlins Rear Adjuster Extension Kit, 996/997 (still in plastic baggies): 107 g | 0.24 lbs
Ohlins R&T Coil Over Kit (still in original shipping box): 22226 g | 49 lbs
Tarett GT3 Style Front Swaybar & Bushing Kit, all 996/997/991/986/987/981/718(in plastic including bushings): 3337 g | 7.36 lbs
Tarett GT3 Style Rear Swaybar & Bushing Kit, All 996/997/991 (in plastic including bushings): 1814 g | 4 lbs
Tarett Drop Link (pr), Front, 996/997/986/987/981/718/991/992 (not PDCC) OHLINS (still in plastic bag): 1372 g | 3.02 lbs
Tarett Drop Link (pr), Rear, 996/997/991/992 OHLINS (still in plastic bag): 606 g | 1.34 lbs
Total weight for everything going in: 32370 g | 71.36 lbs
Well it has been since the last post since I'd really driven the car. I hit a deer the day before my shop appointment to get the suspension done. Well the car is back and the suspension is installed. What a game changer, I should have done this long ago. The car feels like a completely new car on the Ohlins compared to the PSS9s. They are currently set at 8 clicks from full hard on the front and 7 clicks from full hard on the rear. Even with those settings it is firm but not jarring, I only got one drive in before the rain but so far, the turn in is greatly improved, especially on lower speed tight turns. It is much much more confidence inspiring on the faster sweepers and corner way flatter. I feel like I'm more telling the car what to do vs asking for it to turn as with the PSS9s. I'll try and get more feedback but it is now raining all week so I doubt I'll get out again.
