996 Turbo Forum 1999-2005
Updated Litronic Headlights for the 996.2!
Old 11-19-2021 | 02:46 PM
  #31
Capt. Obvious's Avatar
Capt. Obvious
Yes. 2001 Turbos got the .2 (2002+) headlights.
Carlo_Carrera (11-19-2021)
Old 11-20-2021 | 03:39 PM
  #32
Iridium's Avatar
Iridium
Yeah I am totally interested in the difference with their bi-LED kit and how it compares to their Xenon kit. They don't really state it in their specs, so other than it being LED I can't tell if there's a perf difference.
Old 11-25-2021 | 11:13 PM
  #33
Testdr's Avatar
Testdr
FYI. They are having a 20%off black Friday sale right now.
Old 11-25-2021 | 11:16 PM
  #34
LinwoodM's Avatar
LinwoodM
Well damn. Never would have expected a European based company to have a Black Friday sale…
Old 11-26-2021 | 03:38 AM
  #35
2jzhx60's Avatar
2jzhx60
Here's the Black friday code: RFLFRIDAY
Just ordered the kit for my 996 turbo with Litronics.
Old 11-27-2021 | 11:41 AM
  #36
LinwoodM's Avatar
LinwoodM
Mine came in the mail yesterday. They look very solid and good quality. I am actually shocked at how much stronger they seem compared to the retrofit I did on my Tacoma about 10 years ago. I am excited to get these installed on Monday.
Testdr (11-27-2021)
Old 12-02-2021 | 02:49 PM
  #37
LinwoodM's Avatar
LinwoodM
All finished, not I just have to wait until it is dark to aim them. Here is a small comparison of OEM vs these projectors (OEM on the right/both bulbs are Philips Xtreme)…
The following 4 users liked this post by LinwoodM:
Capt. Obvious (12-02-2021), paopao (12-02-2021), TheDeckMan (12-03-2021), tom__w (12-02-2021)
Old 12-02-2021 | 11:08 PM
  #38
paopao's Avatar
paopao
The difference is very clear in the crispness of the cutoff. I've had this kit laying on my workbench for a couple months now; you've inspired me to put some time into it tonight though.
Did you run into any issues fitting the projectors? Last time I looked into my headlight I know the wiring was crumbling just by looking at it!
Old 12-02-2021 | 11:28 PM
  #39
LinwoodM's Avatar
LinwoodM
You nailed it! My right lights wiring was crumbling to pieces, so used shrink wrap u til I order some new crimps to rewire it. Other than that, I had to tap into the high beam wires (brown and white) for the new ones to work. It was pretty straight forward. None of the videos showed the electronic leveler though, so that may intimidate some. Just remove the screws and it pulls right out (the tip will need to be popped out though).
Old 12-03-2021 | 02:24 AM
  #40
Testdr's Avatar
Testdr
Did you have to remove the screw-type level adjustment mechanism?
Old 12-03-2021 | 10:19 AM
  #41
LinwoodM's Avatar
LinwoodM
Yes, it comes off very easy. Remove the electronic leveler (2 screws), then pull it out slightly, about a 1/4” (the flat part against the housing sits behind a tab, you will have to slightly pry it up to slide it out. You will see what I am talking about when you do it, super easy), then pop out the manual adjustment screws, then it will pull all the way out. This is a simple, low stress process. The hardest thing about this whole job is not dropping screws into the housing. I used a magnet to ensure I wouldn’t drop them.
paopao (12-03-2021)
Old 12-03-2021 | 10:24 AM
  #42
paopao's Avatar
paopao
I did one side last night. I'll add that the projector housing bracket has 2 balljoint connections that you will need to pop loose before you can remove it from the headlight, and 3 Torx screws that hold the project housing to the high beam reflector.
Old 12-03-2021 | 10:54 AM
  #43
LinwoodM's Avatar
LinwoodM
You are 100% correct. My passenger side had three torx and the driver side had four torx. When you do the other light, can you snap a photo of the leveling mechanism with the tab I was speaking to in my previous post? That was not in the video..
Old 12-05-2021 | 03:41 PM
  #44
paopao's Avatar
paopao
Shot of the tab on the leveling mechanism is below.
Also, since these projectors are bi-xenon, I decided to delete the plug for the halogen hi-beam (wiring was brittle anyway) and just left the bulb in place. I used the supplied hi-beam solenoid pigtail and wired it directly to the original signal wires for the halogen hi-beam after cutting out all the brittle wiring.
The following 2 users liked this post by paopao:
LinwoodM (12-05-2021), Testdr (12-06-2021)
Old 12-06-2021 | 10:23 AM
  #45
NoogaSparrow's Avatar
NoogaSparrow
I'm a bit confused... Turbos already have Bi-Xenon standard, right?
So why do you have a halogen for your hi-beam? I think I misunderstood what you're saying..
Quick Reply: Updated Litronic Headlights for the 996.2!
