996 Turbo Forum 1999-2005
Installing Chinese coilovers on my Turbo.
Old 03-23-2022, 01:13 PM
  #91
69911
69911's Avatar
Originally Posted by 02996tt
I did read on the forum where one guy got some that were assembled with the right and left top hats switched. I called feal but they assured me that was not the case.
Yea, I am that guy. I am disappointed that Feal would say that when Mike Monterone from Feal told me that "the L/R stamping is likely incorrect from side to side. ". Below is the full email response from Feal:
I also requested that they contact others who may have received improperly made parts. It seems that not only did that not happen, but they denied the problem when asked.
It is how you deal with problems that are often more telling than anything else.
Note: He was incorrect that swapping the entire assembly would work as the AWD has an asymmetric angled spacer. The left/right top mount needs to be swapped on their respective assemblies.
That being said, the dampers and standard 441 spring rates work well for the car and quality, thus far, seems good.
Beginning of email response
Wed, Jul 21, 2021
Hi Ed,
Apologies for the delay in response! My engineer had the chance to review your photos and believes that the L/R stamping is likely incorrect from side to side. He believes that if the shocks are swapped from left to right and clocked correctly then everything should line up correctly and resolve the caster issue you have run into. Sorry about the confusion in the parts and thank you for your continued patience in the matter.
Thanks,
Mike Monterone
Shop Manager
Feal Suspension, Inc.
3496 Hwy 2
#282
Wrightwood, CA 92397
USA
End of email response
Old 03-23-2022, 02:49 PM
  #92
s65e90
s65e90's Avatar
Originally Posted by Capt. Obvious
Pretty much all adjustable top plates require you to drop the shock to access the camber adjustment. It's just a design limitation of the car.
No, they're just using cheap universal top mounts. Look at the Elephant mounts.
Old 03-23-2022, 02:50 PM
  #93
s65e90
s65e90's Avatar
Someone here I think cut their strut mounts to allow adjustment in the car. I looked at it and decided against that lol.
Old 03-24-2022, 02:23 AM
  #94
alxdgr8
alxdgr8's Avatar
Originally Posted by Mike_Feal
I'd say our standard 441's compare directly to the performance of an Ohlins Road and Track style shock. We've done quite a bit of testing on our own 996 and feel like we have nailed a great formula for the car. I've seen quite a bit of positive buzz online about the 996 offerings in specific and I'm very confident you would be satisfied with what we have to offer!
Thanks for chiming in here Mike!
For a daily driven 99% street car do you think it's worth it to upgrade to the Swift springs (441+) or are the Feal springs on the 441 adequate?
Old 03-24-2022, 03:30 AM
  #95
Bernard IV
Bernard IV's Avatar
Probably not worth it unless you are going with stiffer springs with custom valving.
Old 04-05-2022, 04:56 PM
  #96
ceeyahd1
ceeyahd1's Avatar
Was looking to go with Bilstein B8 and H & R springs but after reading the reviews on the Feals I decided to try them out. I do not track my car and this would be for street use. I am planning on getting the standard 441 with upgraded radial bearings. Do I need to purchase anything else? I am not doing the install and want to make sure I purchase everything needed to do the front and rear.
Thanks in advance.
Old 04-05-2022, 05:49 PM
  #97
Bernard IV
Bernard IV's Avatar
If going low you may need rear toe arms to get the alignment into spec.
Old 04-06-2022, 12:31 PM
  #98
ceeyahd1
ceeyahd1's Avatar
Not going much lower than stock. I won't need any bearing plates or strut mounts? Sorry total newbie here, was told I need these with the B8 setup. Trying to make sure I order everything to give my mechanic to install.
Curious to the purpose of bump stops and if I should add them to the order? Will I need the extended damping adjuster?
Old 04-06-2022, 04:03 PM
  #99
Bernard IV
Bernard IV's Avatar
No to other stuff, yes to the extenders.
Old 04-06-2022, 05:45 PM
  #100
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,528 Likes on 1,598 Posts
You only need the extenders if you were going to be tweaking the ride quality often. When I installed my Feals I fiddled around with the adjustments for about a week and then found the settings I like and haven't touched them since. It's been almost a year.
Old 04-06-2022, 07:20 PM
  #101
ceeyahd1
ceeyahd1's Avatar
Great. Thanks for the information.
Old 05-29-2022, 12:01 AM
  #102
kamlung
kamlung's Avatar
finally getting to installing the front... what's the consensus on the install? remove the 6 allen bolts where the axle bolts to the diff (do i need to remove the under plastics to get to this?) or remove the axle nut at the hub?
Old 05-29-2022, 12:46 AM
  #103
Bernard IV
Bernard IV's Avatar
You can pull the suspension down until it fits in outside the fender and then you slip it back under the fender. Careful not to mess up the lip of your fender, put some tape on there for safety.
The following 2 users liked this post by Bernard IV:
carbonjim996tt (11-24-2022), Carlo_Carrera (05-29-2022)
Old 05-29-2022, 10:38 PM
  #104
kamlung
kamlung's Avatar
how did you angle the knuckle? i'm assuming you had to disconnect either side of the axle.. is it easier to go from the diff side or the axle nut?
i have enough of the strut unbolted from the top but i can't articulate it enough to get the angle to get it out of the fender. right now the axle is still connected and the lower ball joint is almost impossible to fit a separator on... everything else is disconnected (caliper, tie rod, forward arm)
thanks for the help...
Old 05-30-2022, 08:03 AM
  #105
s65e90
s65e90's Avatar
You may need to pop those bolts off the axle to get the articulation to install. I don't remember if I did. Just remember to push it back in to snap back into place in the diff.
Quick Reply: Installing Chinese coilovers on my Turbo.
