Boost maxing at .5 bar :(
I have a Cobb tune that was working at 1.2 bar and now it’s maxing at .5, I pressure tested at 20psi from turbo to turbo and found a few leaks and fixed those and now it’s holding fine
i reloaded the tune again but no difference, looked at the maf and it looks brand new, I took the divertor valves apart and verified they are fine, zip tied every connector I could find including the n75, no errors on the ecu, no white smoke
any ideas? I am lost on why this is happening, the car only has 28k miles
double check that there are no leaks. Then check your wastegates. You can then log whats happening and look at the n75 duty cycle. If there are no leaks, then one or both wastegates are stuck open... at least thats my bet
So does the car boost to normal levels, .7 to .8 bar, without the Cobb tune?
so that is a terrible idea. If you unhook the pressure pipe to your wastegate, so that no pressure feeds back to it, the turbo is going to go as fast as it can. One of two things will occur, perhaps both. The turbo will spin itself to death, or the engine will explode. Its very unlikely the n75 died, but who knows. In any case, you should be logging the duty cycle on the n75 and see whats happening there. Also you can make sure the wastegates are working by appying pressure at the actuator.
pretty simple to bench-test an N75 valve...
pfbz (06-18-2020)
Good to hear the N75 valve fixed the problem. Suncoast say this is a common problem, https://www.suncoastparts.com/product/SKUN75.html and they are so cheap I don't know why you wouldn't even try this first.
I keep a spare N75 in my parts box!
did you diy it? and if so, is it just two screws or do i need a t20 security etc like needed for the maf?
