When I first got my car I sent it in to the remapping centre for stage 1 tune up.
After they tuned it they told me it had a boost leak thats why it is low on horse power .
After checking the car over I discovered that both my turbo casings cracked and corroded.The shaft in one of the turbos had basically collapsed
The reason I posted the graph is to see if anyone who knows what there talking about can comment to whether my car is in a safe state at 650nm of torque.
Have they tuned it to an unsafe state ?
Are you asking if a tune caused your turbo to blow?
Or are you asking if its safe in general to use with blown turbos which the answer to that question is a no.
If the graph shown was produced in 2019 (November) and it is now June 2020 and you have a hole and buggered turbo - you can safely assume that no, it is not safe...
What mods would the car need to make 650nm of torque ?
Why have they tuned it to that ?
Thats why I'm concerned never mind the fact that a simple boost leak test would of stopped the remapping procedure
they've obviously thought I'll remap it anyway and take his money.
You should do boost leak tests before a tune but you dont need to. That is a lot of torque for a car with boost leaks though, wgs must have failed closed and really overspun the turbos.
Maybe a tuner will see this and give you insight.
you shouldnt turn your car on until all that broken stuff is fixed.
