996 Turbo Forum 1999-2005
996TT shake down
Old 04-23-2020, 02:52 PM
  #136
s65e90
s65e90's Avatar
Originally Posted by wkf94025
Alternator is out, with the help of a little bit of pry bar leverage. The threaded bushing at the far end of the long bolt seems very frozen in place. I put the long thread rod back in, minus three turns, and "three gentle taps" per service manual didn't do squat. Larger hammer and greater force did nothing either. I threaded the shorter bolt into the bushing all the way, thinking maybe hard torque would free it up. No joy there either. I think I can get it back in as is, but would be nice to free it up. Liquid wrench tonight, one more try tomorrow.
GBox 2nd gear detent arrived. What a ridiculous price for this widget. ($206 incl tax). If it's not patented, would someone please machine an alternate source? Yikes.
Send the detent back. You can accomplish the same thing with a $.50 ball bearing from Porsche.
Old 04-24-2020, 07:39 PM
  #137
wkf94025
wkf94025's Avatar
Thanks for the guidance on the G-Box detent. I will return it, likely suffering their 20% restocking fee. Embarrassed I didn't do better research before hitting Buy Now. Looking forward to the 50 cent fix.
Someone somewhere, perhaps on another alternator thread, suggested putting some heat on the frozen threaded bushing. I assumed that should be with my [propane?] plumbing torch? As opposed to my heat gun, soldering iron, or hot air reflow gun? Should I apply heat to the alternator body surround, the steel bushing itself, or both? Then try to loosen it while it's hot or wait for things to cool down? Haven't thawed a frozen part with heat before.
I did make a modest financial sacrificial offering to the Snapped Bolt Gods in the form of purchasing four small Cobalt bits and corresponding extraction tools, hoping that these will keep said gods from f*cking with me on this 20 year old engine. Though obviously my time is coming in that regard.
Old 04-24-2020, 08:03 PM
  #138
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,324 Likes on 1,481 Posts
Use a plumbing torch. Heat just the outside of the surround, not the bushing itself. Do it fast, hot and direct and then immediately work the bushing to free it.
Old 04-24-2020, 09:02 PM
  #139
s65e90
s65e90's Avatar
Tim on 6speed has an excellent write up of installing the ball bearing on the detent spring which effectively places pressure on the detent spring. It's even a Porsche part. I think I paid like 40 cents for it years ago. It's a little tedious install, but I did it without removing anything but the rear wheel. You just need to get creative with extensions, wobbles and bits.
Old 04-24-2020, 09:18 PM
  #140
k9turbo
k9turbo's Avatar
good advice. it is a highly informative thread.
https://www.6speedonline.com/forums/...n-do-pics.html
Old 04-25-2020, 03:08 AM
  #141
wkf94025
wkf94025's Avatar
@Carlo_Carrera thanks for guidance on the torch. It worked. Threaded bushing is loosened up, and hammered toward front of car enough to be flush with the alternator arm surface. I believe that will make re-install simpler/easier.
@s65e90 and @k9turbo thanks for the 6speed link. I saw that thread a few days ago, and good to know that's the best source for the 50 cent mod.
Voltage regulator removed from Alternator. Check out the difference in brush lengths between old (right) and new (left) regulators. Fingers crossed this explains the low and wobbly charge voltage, and that nothing else is bad on the alternator. Anyone an expert in decoding Bosch VR codes?
Old 04-25-2020, 09:56 AM
  #142
wkf94025
wkf94025's Avatar
Here is an old thread on Pelican forum that does a nice job describing alternator removal/replacement, and also discusses the various Bosch part numbers for voltage regulators that appear identical in form factor and similar/identical in performance, on his Porsche. My VR part numbers aren't an identical match, though I suspect the new one is going to work just fine.
EDIT: both AutohausAZ and Pelican web sites confirm the new part number works for the 996TT (and other non-TT 996's). If the internet says so, it must be true, right?
Old 04-25-2020, 10:15 AM
  #143
Carlo_Carrera
New regulator is correct.
Old 04-25-2020, 10:31 AM
  #144
wkf94025
wkf94025's Avatar
And if you're comfortable soldering, you can attempt to turn a $40 repair into a ~$14 repair by buying new brushes only, something like
these these
. Or cheaper still, something like
these these
$5 brushes. Assuming bearings seem solid and freewheel pulley is smooth in driven and freewheel modes.
EDIT: how do you disable the annoying Amazon graphic and newline when inserting a link to something on amazon? Just want a plain text hyperlink.
Old 04-25-2020, 10:36 AM
  #145
Carlo_Carrera
There is probable more things wrong with the old regulator than just brushes. Replace the whole thing.
Old 04-25-2020, 04:43 PM
  #146
pfbz
pfbz's Avatar
Received 2,743 Likes on 1,473 Posts
Exactly. Brushes are pretty simple and yours look like they were probably be fine ... I think the endemic fault in our alternators is the regulator circuitry itself and $40 is a gift compared to the $3,000+ your local friendly porsche dealer would likely charge you for a full alternator replacement!
Old 04-25-2020, 07:52 PM
  #147
wkf94025
wkf94025's Avatar
Originally Posted by pfbz
...compared to the $3,000+ your local friendly porsche dealer would likely charge you for a full alternator replacement!
Is that what a dealer would charge? Has anyone had their local Porsche dealer replace their alternator? Very curious.
Old 04-25-2020, 08:22 PM
  #148
pfbz
pfbz's Avatar
I'm sure it would be ridiculously expensive...
I'm showing list price for a Porsche-boxed alternator at ~$1,800 (997-603-012-07), local dealers almost always bump it up 10% or so above 'list', plus 3+ hours of labor at $180, shop supplies, etc. and I bet it would be close to $3K at most dealers.
It's really shocking how affordable it is to maintain our Turbos if you do most of the work yourself, fix rather than shotgun parts changing, and buy OEM parts instead of the identical part repackaged into a Porsche labeled box.
The following 2 users liked this post by pfbz:
Capt. Obvious (04-27-2020), Dingo (04-26-2020)
Old 04-25-2020, 08:25 PM
  #149
johnsjmc
johnsjmc's Avatar
The alternator is about $1500 plus $250 for the pulley. Labor @$150/hr at my local pcar dealer I would guess about 3 to 4 hours plus tax. How many hours will you have in it including diagnosis ?
locally I can buy a new replacement unit for something like $300 no exchange needed. I seem to recall it's the same as a vw part.
Old 04-25-2020, 08:29 PM
  #150
k9turbo
k9turbo's Avatar
I'm showing list price for a Porsche-boxed alternator at $1,950, local dealers almost always bump it up 10% or so above list, plus 3+ hours of labor at $180, shop supplies, etc. and I bet it would be at least $3K at most dealers.
agreed, dealers are insane and usurious. i replaced mine with a reman bosch ( about 400? ) a few years ago and *we* did it in about 2 or 3 hrs in my driveway.
Quick Reply: 996TT shake down
