Turbo clutch upgrade advice please
I have a AWE700R 996 turbo. She puts down around 580whp and 570ish wtq. I am in need of a clutch replacement. I want a clutch setup that can handle 800+whp/wtq. The car came with the awe kit and it seems from the build sheet that an Sachs stage 2 was installed. Not a 2.5 or 3. Im guessing this is why this clutch is on its way out in 12k miles only because thepressure plate on the 2 couldn't handle the torque. I've only had the car four about 1500 miles (4 months) and am a pretty good driver with a manual. I rev match my downshifts and on all the cars I've owned this is the first time I've had to do a clutch.
I will be doing gt2 slave conversion and welding coolant fittings at the same time. I may not need a new flywheel but please make your best recommendation both with dual mass flywheel and another with lightweight flywheel option (which I would like).
Thanks in advance
Ps I did the search but many were outdated. Just want to know the recommendations from experts on here as well as Kevin and Sharkwerks e.t.c. and even purchase what I need from Kevin since you seem to be the guru of these cars.
Thanks in advance
he hasnt answered my pm either. Any way I can call him direct? Does he own a business? I want to get the perfect setup.
If you want a 800HP rated clutch you will need a twin disk setup. Tilton would be the best setup.. If you want a 600WHP clutch go with the Sachs 2.5 or SRE with 4.0 clutch disk/764 RS flywheel.
If you are drag racing go with the Tilton or Twin disk.
http://ultimatemotorwerks.com/clutch.html
If you have the Sachs 2.0 kit, most likely you have the Sachs 752 pressure plate>not enough clamp force.
You can email me kevin@ultimatemotorwerks.com
I got tagged at 3:57 Seen the notification and responded at 5:10 I'd say that's pretty good??
Ironically, I was just thinking about this today. I don't need a clutch but would like to have a plan for when I do. I do like how the stock clutch feels, perhaps I am the minority. But I will definitely give you a call Kevin when I'm ready.
I think you aren't alone. I was tempted to go gt2 when I replaced my slave recently but since I am street only I stayed OEM and I am very happy so far. Never stalled the car a single time in 6mo of ownership and find my pickup very consistent.
