996 Turbo Forum 1999-2005
dash lights
Old 11-27-2019 | 06:32 PM
Ciiidds's Avatar
Ciiidds
Default dash lights
a restart to a previous thread. My dash lights are out in my 2004 turbo. I checked my fuses and they all appear ok. any more ideas?
Thanks!
Old 11-27-2019 | 07:10 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Have you played with the dash light level/dimmer control?
Old 11-27-2019 | 11:03 PM
Ciiidds's Avatar
Ciiidds
I looked at the manual and the control only seems to reset my trip log
Old 11-27-2019 | 11:27 PM
Carlo_Carrera
Turn on your headlights and turn/rotate the **** that is to the upper left of the tachometer clockwise. Do not pushing it in, just rotated it clockwise and hold it there. The dash lights should get brighter.
Old 11-27-2019 | 11:59 PM
Ciiidds's Avatar
Ciiidds
Thank you. They came back on! Happy Thanksgiving!
Old 11-30-2019 | 02:22 AM
pfbz's Avatar
pfbz
...if only all the worlds problems were so easily solved!
Old 12-22-2019 | 05:15 PM
Ciiidds's Avatar
Ciiidds
Well, not so fast😕 The dash lights do come on but only for a couple of minutes and then go off. Turning the headlights off and on does not get the dash lights to come back on Only way hey seems to come back on is after leaving the lights off for an extended period. I tried the dimmer control and it only worked once I am beginning to think I am having a significant electrical problem beginning I appreciate all the help!
Old 12-25-2019 | 01:01 PM
NineNine6TT's Avatar
NineNine6TT
Default Related question
So my gauges and dash lights work fine —except the oil pressure ‘needle’ light. So it’s not visible at night.
Am I looking at pulling the dash and replacing the needle/bulb, entire gauge/cluster or is there a work around?
thanks
Quick Reply: dash lights
