996 Turbo Forum 1999-2005
DE tire check in
Old 03-16-2019, 12:34 PM
etchhead
etchhead's Avatar
Default DE tire check in
Hey folks I’m back in a 996tt (AWD) with decent track capability and bought some new APEX wheels 9”/12” and need tires. I’ve ran NTs on previous cars and enjoyed the performance/value and will go that direction again I suspect as I need to move quickly. the car is ~GT2 height and will be aligned well. I know I need to watch front rear ration <3%.
235/315 is an easy option
245/305 was what is used on my GT3. Per Discounttire they are 26” diameter. Anyone using this on an AWD car? How is fit/rub?
NTs are tried and true but really enjoyed my Cup2s on the 350R and 7.2TT as well.
Thoughts please.
Old 03-16-2019, 02:07 PM
03EvoIII
03EvoIII's Avatar
I'm running the falken rt615K in 245/315 sizes on the same wheels as you. Probably not as aggressive of a tire as you want but no rubbing for me yet on x73 suspension.
Old 03-16-2019, 02:45 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,531 Likes on 1,600 Posts
Go with 245/315. Perfect specs for AWD.
Old 03-16-2019, 03:37 PM
etchhead
etchhead's Avatar
Cheers guys and John- 245/315 it is. Will update when I get her here and sorted.
Old 03-16-2019, 06:37 PM
Road King
Road King's Avatar
The good news is that if you want to go with the Falken RTK-615+ tires, both the 235/40 and 245/40 are taller than the 315s, so you can choose either and not have to even think about the AWD and front / rear tire heights.
Old 03-16-2019, 06:45 PM
993GT
993GT's Avatar
don't have many miles on them yet but the A052 seem to be much stickier and more importantly have better stability/response vs the Rt615k+
will see how treadlife and heat cycling is as I get more time on them
Old 03-16-2019, 09:37 PM
PaleAle
PaleAle's Avatar
Hey Carlo, why? The original 18" diameter difference waswas .1" greater on 18" stock. I've been trying to find new tires for my 19" HRE's and the closest I've found is 235/315 at .3" greater in the front. 245/315 is .6" greater in the front.
235/35/19 & 315/25/19
Old 03-17-2019, 12:09 AM
Carlo_Carrera
I believe the OP is talking about 18" Nitto NT-01 tires for DE/autocross. A 245/40-18 NT-01 is .2" larger diameter than the 315/30-18 rear. It is best 18" combo I have found for AWD compatibility and front/rear grip balance.
Old 03-17-2019, 02:14 AM
jayzbird
jayzbird's Avatar
I had some rubbing on the rear inside fender liners on track with 315 NT01s. 7mm spacers solved it.
Old 03-17-2019, 09:46 AM
jdexter
jdexter's Avatar
You can get the gt2 fender liner mounts to cure that. They are like $25. Google powdrhounds post on it.
Old 03-17-2019, 11:00 AM
etchhead
etchhead's Avatar
With your new 9”/12” Apex wheels what if any spacers are you using and are you lowered? Fenders rolled yet?
cheers all!
Old 03-17-2019, 12:54 PM
03EvoIII
03EvoIII's Avatar
Rob,
Are you just using the A052s for track use? I almost went with those but wanted a little more capability on the street as well.
Old 03-17-2019, 12:59 PM
03EvoIII
03EvoIII's Avatar
cheers all!
Interested about this question as well.
Old 03-17-2019, 02:41 PM
993GT
993GT's Avatar
full time usage, street and track
Originally Posted by 03EvoIII
Rob,
Old 03-17-2019, 03:29 PM
03EvoIII
03EvoIII's Avatar
Great - curious to hear about your experience with them long-term. Maybe for my next set..thanks!
Quick Reply: DE tire check in
