2001 996 turbo ignition/electrical problem?
Hello. I am a relatively new Porsche owner. I have a 2001 996 turbo with 34k gentle miles on it that I acquired from its first owner two years ago with 32.9k miles. Well maintained throughout. Recently I noticed while driving that the heating/air conditioning fan was not working. The next day, however, it did work but the headlamps would not turn on (even though the parking lamps and driving lamps did). When I took the key out of the ignition that same day the warning alarm came on and the dashboard said that the key was still in the ignition. The dashboard lights remained on as well. When I tried to put the key back into the ignition, it would not accept it without a lot of coaxing. When I again removed the key the same alarm and warning came on. I am now unable to lock or arm the car with the button on the key. I can only lock the car by putting the key into the door lock. It still will not arm and the steering wheel does not lock. When I can get the key into the ignition, the car starts and runs fine but I am now afraid to take it anywhere for fear that I will not be able to get the key into the ignition and start it. Are these problems with the fan, lights, and ignition related? Is this a common or recognized problem? Easy solution or tough fix?
Thanks for the rec. I have no experience working on cars and am reluctant to dig under the dash. The shop where I have taken the car before has recommended (over the phone) that the entire ignition assembly be replaced and not just the ignition switch. Is that an up sell or a reasonable recommendation?
Put another way, replacing the entire ignition assembly to fix this problem is the equivalent of replacing an entire taillight assembly because a taillight bulb burns out. It might take you a few minutes to figure out how to get to the bulb and swap it out, but once you've done it the first time, you'll laugh at the thought of replacing the entire assembly to swap that inexpensive little part out. I would highly recommend that you get comfortable with doing some minor maintenance work on your car yourself because it will make the car much less expensive to maintain, and you'll learn to enjoy the DIY experience - it makes you more connected with the car. There is so much info and help here, on YouTube and on other Porsche forums, that it really doesn't make sense to take it to the shop every time you have a hiccup. If you do get into that habit of taking it to the shop for everything, then get used to having quick & easy $30 repairs turn into $600+ shop bills - which will ruin your ownership experience.
