installed GT3 Seats in my 02 996TT airbag failure light
#31
Correct. Probably wasn’t clear but that’s what I meant. The plug runs off the seatbelt receptacle. It’s all OEM stuff.
#33
#35
Basic Sponsor
Done. Here is what I learned ('02 Turbo):
- Battery not disconnected. No key near the vehicle - on a battery tender the whole time.
- Removed factory seats - unplugged main connections to seat heater, motors, etc.
- Bolted factory seat belt receptacles to the GT3 seats.
- Ran belt receptacle cable to the underside of the seats.
- Plugged the green plug in with the prong thingy sticking outward/away from the female plug on the drivers side.
- Plugged the blue plug in with the prong thingy sticky outward/away from the female plug on the passenger side.
- Zip tied all wiring and loose plugs to the underside of the seats.
- Bolted down the seats.
- Turned the key to ON - no airbag warning.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
#36
So there was no need to move the passenger seat weight sensor over to the GT3 seats?
#37
Basic Sponsor
Hopefully have a set of these seats showing up soon. Dave, in your pics above you didn't route the shoulder belt through the outside hole in the seats? I also see that you have the seat belt receptacle on the outside of the seat against the transmission tunnel. Shouldn't that also be routed through the hole and be inboard to the seat?
#40
#43
Ok, so the shoulder belt gets routed through the upper and lower holes of the seat but the seatbelt receptacle stays on the outside of the seat. Interesting, I thought both were routed to the inside of the seat.
