Anyone have their 6GT2 on the scales?
Curious if anyone with a 6GT2 has had their car on the scales and could post up the corner balance data. I'm curious what about the weight distribution. Post up whether that is with full fuel, driver, what mods, etc. Thx..
You may already have seen this, and it isn't my personal data, but I have this saved in a spreadsheet under the many suspension setup/alignment posts that I have taken data from.
From 996GT2 euro spec, club sport.
Source: https://rennlist.com/forums/996-gt2-...alignment.html
hope this helps.
Chris.
Measurements are (in/kg)
LF 266.5. RF 266.5
Total 1464.5
LR 464.0. RR 467.5
Front percentage. Cross(LF/RR) Front total. Left total
36.39%. 50.12%. 533.0. 730.5
Rear percentage. Cross(RF/LR). Rear total Right total
63.61%. 49.88%. 931.5. 734.0
Left percentage. Right percentage. Front bite. Rear bite
49.88%. 50.12%. 0.0. -3.5
Also alignment numbers are:
-3.2 camber front
0.01min toe each side
-2.4 camber rear
0.15 min toe each side
LF 266.5. RF 266.5
Total 1464.5
LR 464.0. RR 467.5
-3.2 camber front
-2.4 camber rear
hope this helps.
Chris.
Thanks. I don't think that's a club sport, I think that's a Euro spec GT2 which is identical to US spec except for the option of the Euro seats. His total weight numbers are pretty much identical to mine, he comes in at 3224lbs while I'm at 3198lbs. What's interesting is that his distribution is more tail heavy at 36.4/63.61% while I'm more balanced at 37.99/62.01%. If he has A/C, the stock exhaust and the heavy OEM wheels, that would likely explain it. Was curious what other GT2 guys are coming in at.
Hi, that was mine from a few years ago.
My car is a euro clubsport, I had full 6point oem cage, 19" 997 gt2 wheels and front and rear Alcon steel rotors instead of ceramics.
Ill try and dig out my laters weights
Cheers
Cheers
