Tire Drought
Thx powdrhound. Found this too: https://rennlist.com/forums/997-gt2-...ng-them-2.html
Could use some help here fellas,
PS2's in 315/30/18 are also a victim of the tire drought. tire rack is out and a few other places i've checked are $550+, so after some research I decided on NT01's. I miraculously sourced a set of NT01 rears in 315/30/18 but can't find 235/40/18 fronts.
Some places do carry 245/40/18, though.
My question to you is...can I run that combo (245/40f 315/30r) on track on a 996gt2 OEM rims without adverse handling etc.
Thanks!
Thanks!
Fawking Spring. Are you kidding?? I need 245 badly and 275 after my wife snuffs out her supply. I can run ventus TD on the M3 and maybe 888 on the GT3. This sucks.
Thanks!
Thanks!
If you can miraculously find 245s, get them now without delay. They are worth gold right now. They've been out of stock for close to 2 months. With that said, 245/40 and 305/35 NT01 is a better set up on the 6GT2. Many 6GT2/3 track rats are swithing to this combo. I've run both the 305 and 315 and find the taller 305 superior on all fronts. Good luck..
If I go forward with them, my setup will be 245/40 315/30 (a combo I haven't seen much of with an 8.5" front while researching).
Cheers
