New Project: Engine drop to do coolant fittings...
#61
Looks great! It's amazing how quickly everything bolts back together. Make sure all the clamps are tight. I had a loose one under the alternator and had to pull off the P/S, A/C, and alternator and pry up their brackets to get to it with the engine still in the car. A couple screw driver turns and it was fixed.
#64
#65
Ready to go in... Glad I replaced the TO bearing as it sounded pretty bad. Got taken over by last shop as they said it was changed 2K miles ago. Improvised a press to remove and install it using my motorhome chassis. Everything went back in smoothly. Double checked all hoses before installing intake. Friend is helping out tomorrow to at least get it into a semi-finished state... I can do minor stuff during the week... Getting close!
![Name: CIMG2123.JPG
Size: 1.06 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/784978d1386388762-new-project-engine-drop-to-do-coolant-fittings-cimg2123.jpg)
![Name: CIMG2191.JPG
Size: 1.06 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/784979d1386388762-new-project-engine-drop-to-do-coolant-fittings-cimg2191.jpg)
![Name: CIMG2192.JPG
Size: 1.07 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/784980d1386388762-new-project-engine-drop-to-do-coolant-fittings-cimg2192.jpg)
![Name: CIMG2188.JPG
Size: 1,021.2 KB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/784981d1386388762-new-project-engine-drop-to-do-coolant-fittings-cimg2188.jpg)
![Name: CIMG2189.JPG
Size: 1.13 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/784982d1386388762-new-project-engine-drop-to-do-coolant-fittings-cimg2189.jpg)
#67
Update... Good news is that the engine was installed yesterday with help from a couple of friends. Went in relatively easy. Glad they were there... I spent 3 hrs this AM completing and double checking the coolant and electrical connections. It started as soon as FI got pressure.
Unfortunately, there is a coolant leak from one of the welds on the connector right on top of the water pump... I thought something was not right wen I vacuumed the system to refill with coolant and it did not hold. So, the rear cooling manifold needs to come out. Got to undo rear engine support, cats and cross over pipes, AC compressor and its mount along with PS pump and right hand cam oil return line.
At least, o-rings are new and hoses are pliable and everything is still fresh in my mind. Glad it was not one located in the core of the engine... Minor set back...
Done for the day. Beer time!
#68
Something I completely forgot and feel like **** for not saying now. My fab guy pressure tested every piece before considering them done in order to avoid the leak you had. He's pressure tested all 4 cars he's done the fix on and as a result none of us have had any issues with the welds.
#69
It's out! Took about 1.5 hrs doing a partial engine drop.
Had to undo the eng mounts as the O2 sensor connectors would not come out between the body and eng support. Once mounts were off, i was able to slide them around.
I moved the AC compressor out of the way and left the base in place but loose. I was able to tilt the front of the base upwards to give me enough clearance to pop front manifold out once hoses were loose. There was enough give with the new Orings (I lubed them while installing)
Had to undo right oil cam return hose. Just a bit of oil lost. Oil filler clamp needed to be loosened along with oil return line on top of engine to give clearance for front piece to come out.
Not too bad all things considered. Piece goes back to welder tomorrow. And hopefully pick it up on Fri to complete over weekend!
![Name: CIMG2219.JPG
Size: 1.06 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/785962d1386725486-new-project-engine-drop-to-do-coolant-fittings-cimg2219.jpg)
![Name: CIMG2221.JPG
Size: 1.01 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/785963d1386725486-new-project-engine-drop-to-do-coolant-fittings-cimg2221.jpg)
![Name: CIMG2222.JPG
Size: 1.13 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/785964d1386725486-new-project-engine-drop-to-do-coolant-fittings-cimg2222.jpg)
![Name: CIMG2223.JPG
Size: 1.05 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/785965d1386725486-new-project-engine-drop-to-do-coolant-fittings-cimg2223.jpg)
Attachment 785966
Attachment 785966
![Name: CIMG2225.JPG
Size: 1.18 MB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/785982d1386728636-new-project-engine-drop-to-do-coolant-fittings-cimg2225.jpg)
#70
Picked fixed part yesterday afternoon and I'm happy to report that everything is holding up nicely. After I put vacuum tool to refill system, it held steady for minutes. I knew then I had no leaks...
It was just a matter of finishing up then and starting her up... Ran for about 20 minutes, but it was just too cold to get thermostat open (7 pm last night 25F ). So final coolant purge and refill will have to be done sometime in warmer weather...
All that is left is to button up suspension cross members and sways and belly pan... Probably another 2 hrs.
Thank you Porsche...
#71
Great write up, interesting to see if you've stopped the chirping.
#72
Bumping this now the weather is improving and cars are coming out of hibernation.
Did the chirping stop with the changes you made?
#73
It had diminished, I say 75%... I was at the track on Fri... Did not really pay much attention... Next time I'll have it out on the street, I will reevaluate...
#74
