Alignment for a 996 GT3 with Hoosiers
It's a new season and possibly time to try a new alignment? Curious to know what's been working for other 6GT3 folks running Hoosier R6s. Camber, caster, toe? What works, what doesn't?
Thanks in advance!
(note that stock 6GT3's cannot adjust caster).
Thanks in advance!
Depends on your driving style. You really need to get get a "baseline" setting on the car and then run with the Hoosier with somebody taking pressures and more importantly tire temps across the surface throughout the day to get a good reading of what the tire needs. Obviously you can do this a few times a session as you want to come into the pits HOT after everything is fully up to temp (3-5 laps).
Exactly. Great point ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
It is important to understand that while you can run Hoosiers on the stock suspension, it is not the optimal setup as the spring rate of the tire will overpower the stock setup. The shop that really knows what they are doing will be able to match the spring rate of the tire to the proper spring rate range for your car.
Thanks guys, some great info here. I just moved cities and am trying out a new shop; he's setup plenty of race cars but I get the impression not a lot of 6GT3s. Going to start with Camber/Toe of -3.3/0 in the front and -2.3/2mm total in the rear. Open to input.
Great point about the suspension, upgrade is on the list, now with a higher priority! :-D
Search for Kussmaul and you'll get a great information on alignment. These 996 GT3s have had loads of setup gurus tweaking them, but for the most part, the Kussmaul baseline works. Tweak to suit and you're golden.
https://rennlist.com/forums/996-gt2-...ification.html
The settings are below. I am set up a little more agressively on front camber (-2.6) and front toe (zero), but about the same on the rear. Also, my ride height is a couple mm under Kussmaul.
If you are in this range, you should be fine.
-td [sorry for the snarky remark in my first post, but there is a plethora of info on alignment, so I was suggesting a few hours of light reading
![Name: Kussmaul Alignmnent specs.JPG
Size: 45.3 KB](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/618217d1332367279-alignment-for-a-996-gt3-with-hoosiers-kussmaul-alignmnent-specs.jpg)
FWIW I run stiff springs, 750F/900R, and set camber at -3.5F/-1.9 R.
