need diagram for cylinder head valve drive
Can anybody help me get diagram of cylinder head valve drive.
I have oil leak betwen cylinder head and camshaf housing, need to change rubber gasket. Would like to know if i can do that myself.
I can post pictures of the oil leak latter tonight
thank you
thank you
Check out this factory catalogue, might help. Schematics give you an idea.
http://www.porsche.com/all/media/pdf...SA_KATALOG.pdf
Take a look at Serge944 teardown/rebuild thread here: https://rennlist.com/forums/996-gt2-...3-4-liter.html Might show what you are looking for...
so i need to change gasket betwen cylinder head and camshaft housing - looks like i have to remove timing chain?
You need to remove the sprockets on the camshafts and the timing chain slips off. By doing this you lose cam timing. You need to reset it using factory tools:
Serge,
would you know which gaskets or sealer (parts #, loctite#?) i need to get when i am going to put it all together - camshaft housing?
And torque specs?
This is the correct gasket maker for surfaces without a gasket. I even used a bit of it on the chain housing gaskets "just in case."
Here are the engine torque values:
