996 GT2/GT3 Forum 1999-2005
Please Take A look At My Rotor
Old 01-11-2012, 10:56 AM
SH || NC
SH || NC's Avatar
Question Please Take A look At My Rotor
  • Front 996 GT3 Girodisc
  • PFC 06
  • SRF
  • 996 GT3 Cup cooling ducts
  • ~14 events; all PCA DEs in mostly White & Black
Looking at some post-event pictures from November clean up, thinking about replacement rotors sections, and saw this crack in the ‘slot’ I had not noticed before. I don't recall seeing this for my other side front rotor, but I will double check tonight with a flashlight.
Without being alarmist, it looks kinda bad to me, but want a second opinion. My next event is in March at VIR; not sure if I should replace before then.
Is it worth the risk? Of course not, but neither do I want to discard a fully functional rotor either.
SH || NC is offline
Old 01-11-2012, 11:02 AM
LVDell
LVDell's Avatar
Personally, I'd still run them as there is still life in them. However, I would have another set on standby reedy to go should they start to turn south quickly. The thickness is obviously fine based on the slots but the cracking is just starting to get out of control. Any wider or cracking that splits at the edge of the rotor and it I'd change.
12 events or 12 days? Heck, I could only dream of getting 12 days out of a set of rotors! I think mooty only gets 12 minutes per set
LVDell is offline
Old 01-11-2012, 11:05 AM
SH || NC
SH || NC's Avatar
Events. Installed July 2010. Yeah, you know me the pansy braker. Remember with the stock suspension can't upset it too much.
SH || NC is offline
Old 01-11-2012, 11:11 AM
kristap
kristap's Avatar
Change it. YMMV but my rule of thumb has been to gauge depth with a fingernail and if it catches in the crack or the crack extends to an edge - replace the rotor. It's probably ok but not for long and I wouldn't want to guess at "how long" that "long" will be. Had a smaller, more narrow crack than that before our Nov VIR event. Removed calipers for winter rebuild and noticed that crack had virtually exploded into a chasm about 1/2" wide at the outside and completely split the rotor. Again, probably ok but I don't like probably.
kristap is offline
Old 01-11-2012, 11:39 AM
utkinpol
utkinpol's Avatar
Originally Posted by SH || NC
[LIST][*]Front 996 GT3 Girodisc[*]PFC 06[*]SRF[*]996 GT3 Cup cooling ducts[*]~14 events; all PCA DEs in mostly White & Black
PFC get rotors very hot, you may try pagids rs29 pads instead, they do not bite as hard as PFC so it feels different but your rotors may last at least twice longer with them.
utkinpol is offline
Old 01-11-2012, 12:28 PM
4porsh
4porsh's Avatar
i'd run with them, have run with them looking like that and I am running with rotors like that now. But that's how I roll. Do what you and your wallet feel comfortable running.
4porsh is offline
Old 01-11-2012, 01:03 PM
Serge944
Serge944's Avatar
That's one thing about cracks - they propagate. I would do another session and watch the crack. If it continues growing, replace.
Serge944 is offline
Old 01-11-2012, 01:57 PM
Rceron
Rceron's Avatar
I'd rent a garage for that 1st VIR event in March...you'll be happy you did if you have to change rotors at the track that time of the year.
Rceron is offline
Old 01-11-2012, 02:04 PM
dan212
dan212's Avatar
These rotors are done for. I wouldn't use them on the street much less the track.
dan212 is offline
Old 01-11-2012, 02:11 PM
DHI
DHI's Avatar
Are you sure the slot is cracked?
From the picture it appears t me it looks like it's only pad buildup on the one edge of the slot rather than a crack.
DHI is offline
Old 01-11-2012, 02:13 PM
Burger
Burger's Avatar
Replace them. I don't personally like the difference in appearance from the left section to the right section in regards to the wear pattern near the crack. To me, this indicates a difference in level between the sections. Not safe.
Burger is offline
Old 01-11-2012, 02:26 PM
OZ951
OZ951's Avatar
I agree, worth a second look.
OZ951 is offline
Old 01-11-2012, 03:21 PM
SH || NC
SH || NC's Avatar
Thanks for the feedback all.
Never considered pad build up - duh - it does kinda look like that doesn't it - will double check tonight and report back.
SH || NC is offline
Old 01-11-2012, 03:24 PM
996FLT6
996FLT6's Avatar
Thought the slots were wear markers. Once u see no slots time to change. Oh well- good to know. Mike
996FLT6 is offline
Old 01-11-2012, 03:26 PM
SH || NC
SH || NC's Avatar
They might be - can't recall what the Girodisc literature states. Knowing how I brake, I would very surprised if it was a crack.
SH || NC is offline
Quick Reply: Please Take A look At My Rotor
