996 GT2/GT3 Forum 1999-2005
Hoosiers R6 Vs Kumho v710
Old 08-09-2011, 03:20 PM
LVDell
LVDell's Avatar
Steve I ran everything from Nitto's to R6's to Slicks on my Fikse's and never had a rotation issue using the aquanet trick.
Old 08-09-2011, 03:33 PM
996FLT6
996FLT6's Avatar
Could be the tire because on Hoosiers i do the same cold pressures and I get similar hot pressures as u. Mike
Old 08-09-2011, 03:36 PM
Boinkus44
Boinkus44's Avatar
Dell,
I hear ya, and I have to admit I'm a little puzzled by my Fikse experience. I ran probably 4-5 sets of Nittos on the Fikses with no movement at all, but as soon as I tried the R6's, rotation was a huge problem. Worked with multiple tire shops and various remedies, but ultimately new wheels were the (expensive) solution. It frankly doesn't make a lot of sense to me, but a contributing factor may that my Fikses came off a 996 cup and were used for racing for a couple of years so maybe that use/abuse (somehow) made them more susceptible to rotation. Anyways, Fikses soon to be for sale.......
Old 08-09-2011, 04:24 PM
mtesh73
mtesh73's Avatar
Default running sport cups>>>
cold pressure 30, hot 36 all four corners. running stock 18" turbo twists with no rotation of tire on rim. i cant understand how the aquanet holds up to the heat, but many have tried it with success.
Originally Posted by Boinkus44
Not sure if it is a tire issue, ambient temp issue or a set-up issue or a combination of all of the above, but I get a cold-hot pressure rise of about 10 lbs on the front and 14-16lbs on the rears with Hoosiers. Seems like the Kuhmos top out earlier. Curious if your Hoosiers increased in pressure a similar amount as the Kuhmos seem to do. Thanks.
Old 08-09-2011, 04:27 PM
SH || NC
SH || NC's Avatar
The aquanet isn't an adhesive - its a lube for mounting, which then evaporates and remains somewhat sticky, but the sticky isn't what's keeping it on the wheel. Same trick for putting on golf grips.
Old 08-10-2011, 04:04 AM
AllanJ
AllanJ's Avatar
I run Nittos a lot and under hard braking they are chirping like birds. R6....not so much. I think R6 grip the pavement a lot more than Nitto and so they would transmit more force to the wheel, resulting in more potential wheel mounting slippage.
Just a theory.
Cheers,
Old 08-10-2011, 08:35 AM
SH || NC
SH || NC's Avatar
Man, how do you go back to NT01s after running R6s? I've considered the R6 route, but don't think I am ready yet; I hear it is a one way street
Old 08-10-2011, 11:06 AM
Boinkus44
Boinkus44's Avatar
It is. After 3 sets of Hoosiers I went back to a brand new set of Nittos (that I had purchased last year) and it felt like there was something wrong with the car. Had everything to do with new tires and the tread blocks, but really a let down after the Hoosiers. Likely my last set of Nittos.....
Old 08-10-2011, 11:08 AM
LVDell
LVDell's Avatar
Nittos' are just a gateway drug. Once you start smoking the Hoosier crack pipe you sure can't go back to the Nitto starter set
Old 08-10-2011, 11:14 AM
Boinkus44
Boinkus44's Avatar
So true.
Old 08-10-2011, 11:15 AM
LVDell
LVDell's Avatar
How do you think I feel? I went from a GT3 on hoosiers to a Turbo on Nittos
Old 08-10-2011, 11:27 AM
Boinkus44
Boinkus44's Avatar
I applaud your fortitude in overcoming the GT3/Hoosier addiction. But....once sampled, the taste of the 3 is never totally forgotten - or so I'm told. Not a theory I want to test anytime soon.
Old 08-10-2011, 11:28 AM
LVDell
LVDell's Avatar
I have a 1 and 3 year old so I have learned an incredible amount of patience. I know one day soon I will be back in a 3. Most likely a Cup. Just need to wait until they get a little older
Old 08-10-2011, 12:29 PM
Boinkus44
Boinkus44's Avatar
Sounds like a very good plan for all the right reasons.
Old 08-10-2011, 12:30 PM
LVDell
LVDell's Avatar
My avatar speaks volumes to this
Quick Reply: Hoosiers R6 Vs Kumho v710
