996 GT2/GT3 Forum 1999-2005
Damn Splitters keep falling off?? Suggestions...
Old 05-11-2011, 12:21 AM
cfjan
cfjan's Avatar
Previous owner of my car had the race shop change out all the rivets w/ bolts.. it obviously holds really well, but as others have mentioned, if you rip the splitter, you will do damage to the bumper.
On my way home driving in the down pour from New Jersey a few weeks ago, the car hit some standing water (in pretty slow speed) and the Cup splitter caught water and ripped a few holes on one side of the bumper. It is not a big deal, I used some plastic washer for the bolts on those ripped holes.. (I also have 3M double sided tape across) but be prepared that it can happen.
The good thing is that it doesn't come off for "no reason".. (if you just run over grass, scrape the ground, air get in between, etc.)
So you win some, you lose some.. !
Old 05-11-2011, 04:18 PM
AllanJ
AllanJ's Avatar
Originally Posted by JR944
My car is pretty low. Don't run the splitter at all on the street and use the NAPA plastic rivets on the track. Cover the seam with tape as Dell does (not nearly as nicely or with checkered tape though!).
Same here. If you always leave the splitter on then double sided tape is a great addition to the above.
No bolts.
Old 05-11-2011, 06:07 PM
SH || NC
SH || NC's Avatar
Double-sticky tape and factory push pins for me; lip stays on all the time; no drama. My recent re-attachment after spring cleaning and screen install. (link)
Old 05-11-2011, 06:28 PM
911SLOW
Admin
911SLOW's Avatar
Unless it passes the "hitting the cat crossing the road" test..
Old 05-11-2011, 06:56 PM
Crazy Canuck
Crazy Canuck's Avatar
Silicone plus the plastic connectors on mine. Been on for 4 years.
Old 05-11-2011, 07:20 PM
SH || NC
SH || NC's Avatar
You are either:
  1. Driving at the wrong tracks
  2. Your reaction times are falling off
Old 05-11-2011, 07:22 PM
911SLOW
Admin
911SLOW's Avatar
3. all of the above
Old 05-12-2011, 06:51 AM
StevoUK
StevoUK's Avatar
I have a couple of ripped off Cup splitters in the garage to experiment with.
I'm going to try cutting saw slots at 6 inch intervals vertically in the splitter which will allow flexing of a segment that contacts the ground but not significantly reduce the aero effect even at high speed.
Having checked.....
Note - wont work - the splitter is too thick and rigid to allow any flexing........
Quick Reply: Damn Splitters keep falling off?? Suggestions...
