First time on track and big oil leak...(RMS)
#46
Have you considered an aftermarket warranty? Some folks spit on them, but personally, I've had good luck using them. Sometimes there is a little push-pull getting things done - but it's been worth it for me. My 5 yr/ 60K warranty was only $3,000, and I've used well over that since I got it. And I still have a few years left.
-td
-td
#47
-td
-td
#49
Yes for a GT3.
AM warranties typically go by miles and not year. Car had 20K when I got it. I've replaced a few things, including front main seal, two coolant line couplers and a few other minor things.
If anyone wants more info, PM and I'll send it over.
-td
-td
#50
Tom, Please contact me
Tom,
Sorry to threadjack: I may be interested in the seats that you have for sale, but I can't access your contact info (I'm new here). Please contact me.
Thanks,
Jeff
Thanks,
Jeff
#51
I've never felt an LSD bump/thump that bad.
Whilst running at speed on track, when turning right, there was a rhythmic thumping/banging - never felt an LSD do that at speed. Same type of feel, allbeit much slower whilst backing out of the parking spot with front wheels turned to the right. It did not feel normal. Again, at first I thought it was brake pad deposits but I did not feel it when the brakes were applied...softly or with force. Upon my after-track mental summary, there's no way that's a "normal" occurance.
My bet is wheel bearing but I don't know. We'll see.
Could be a wheel bearing. They are not too hard to change with the Sir Tool. It has been quite a few years since I changed one on my previous 996, but if you have 2-3 hours of time you can save quite a few $$. I was quite surprised how easily this was accomplished.
#52
Ace,
Thanks so much,
TomK
Just checked ou the Sir Tools B90...awesome!!! Not needing to remove the hub will save plenty of time and an alignment. Expensive tool but will pay for itself in a couple of years. Thanks again, Stephen.
#54
Man, I wanted to go LWFW so bad but I would've needed to sell the RS wing, but I really do like that thing. Good news was that the clutch is almost new, so no need to replace that.
Limerock bound on June 6th!!!!
BE good,
TomK
#57
Super-secret version??? What, a retrofit from Subaru that really seals?...
BE good,
TomK
BE good,
TomK
Got my RMS done a month ago and the dealer said they installed the "upgraded" version. Not sure how new this is though and never got a copy of the work order so P/N?
#58
You'll need a B90-P3 and a B90-3J add-on as well. I think I paid around 250, but that has been a while
#60
Admin
I have already sent it to Tom but for future reference:
Technical Information Service 1
3/08 EN 1359
Jan 31, 2008
Spacer ring for crankshaft sealing ring (3/08)
Model year: as of 2004 up to 2005
Vehicle Type: 911 GT3 (996)
Concerns: Crankshaft seal on flywheel side.
Situation: Repairs:
- New spacer ring for crankshaft sealing ring,
- Procedure changed in Workshop Manual. From 21 November 2007 onwards, a spacer ring is fitted on the crankshaft sealing ring on the flywheel side on GT3 engines. The spacer ring is fitted between the crankcase and crankshaft sealing ring.
Date of Introduction: 21 November 2007 as of engine numbersM9776 618 24155
M9776 618 29001
Repairs:
The following applies: Engine without spacer ring: The spacer ring must be retrofitted when replacing the crankshaft sealing ring on the flywheel side.
Engine with spacer ring: The spacer ring must be replaced when replacing the crankshaft sealing ring on the flywheel side.
The Workshop Manual has been changed accordingly, see → 135919 Removing and installing crankshaft sealing ring - GT3 (flywheel side).
Part Nos.: 997.101.264.90 → New/Spacer ring
997.102.264.91→ Shaft sealing ring
