correct throw-out bearing for lwfw mod
need help: does anybody know if the RS lwfw mod for the 2004 GT3 requires a different throw-out bearing than the stock bearing? I have gone thru 2 stock bearings in a short period of time; the first suffered a cracked bracket, the second is still in car but beginning to act up and i am about to pull motor to inspect/replace. This is with no clutch abuse of any sort. I don't want to use the same parts if there is a better set up for the car I have heard that the lwfw bearing has a different part number....? thanks for any suggestions
That part number is the pilot bearing for the input shaft into the back of the crankshaft. The throw out bearing for the LWF is 944 116 080 00. This is not the stock bearing that came with the dual mass flywheel setup.
GT3 player par excellence
someone needs to fix the english language.....
Admin
thanks very much, knew there must be something amiss in my setup
