Featherlite trailer.....
Anyone on here use a model 3110 Featherlite? If so, can 996 GT3 be towed with 14' trailer or is 17.5' needed?
Thanks!
Thanks!
I just bought that same model (14') and it works great. Another local 996 gt3 owner has one too and not only was it great, but it was just the right size he put it in his garage with the car on it!
Mine also has a tire rack.
i am also right now in the process of buying the same model from reading all the posts on this forum i kind of convinced myself that most thought the larger size was needed good to hear tthat the 14 ft will work
That slope gets really scary the more I look back
But I need that trailer in order to carry both the 944 spec and GT3 comfortably.
The 944 is fine. Worked out the issues and been running great. I'm finding it tougher to find time to go out and play now that the kids are getting older.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
The 944 is fine. Worked out the issues and been running great. I'm finding it tougher to find time to go out and play now that the kids are getting older.![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Okay, sounds like 14' will work. Thanks. Also guessing that the trailer needs to be 8.5' wide and not just 8', correct? I think the inner width will be REALLY tight if only using the 8' wide version of trailer.
What is the over all length on the 14' FL?
Looking at the FL site, it appears that the 14' trailer comes with 6' ramps, I would strongly recommend at least the 8' ramps with a car as low as the GT3.
yeah, comes with 6' ramps. you can get 7' ramps if you go with the 17.5' trailer. i was just planning on using some pieces of wood (which i think you'd still have to do with the 7' ramp).
