996 GT2/GT3 Forum 1999-2005
Let's talk brake pads
Old 02-15-2011, 01:47 PM
  #31
Serge944
Serge944's Avatar
Originally Posted by ninerguru
Just out of curiosity... are there any differences in OEM f/r bias on cars with steel vs. carbon brakes? I know the rear pad is the same for both, but a larger diameter rear rotor (350mm vs 330mm) would apply more torque all other things being equal.
Are the majority of folks mixing pads on cars that had steel brakes form the factory? What about those that had carbon rotors to begin with, are you happy with the current rear bias? Thanks.
You're only looking at a 6-7% increase in lever arm. I doubt you can tell the difference.
Same master cylinder for all 996 GT3s, so the bias of the hydraulic system is the same.
Old 02-15-2011, 01:52 PM
  #32
DHI
DHI's Avatar
Originally Posted by 007DT
I run Hawk DTC 60. Sometimes DTC 70 on the rear.
Great setup and feel. A lot of PCar friends and racers use them.
Less $ too.
Hawk... no nasty caustic brake dust?
I used to run blacks and then blues in my previous life... the dust was so bad it ate wheel finishes when mixed with water/rain.
Old 03-04-2011, 06:52 AM
  #33
Wild999
Wild999's Avatar
I'm currently running Pagid RS19's both on the front & the rear of my GT3. This set up works very well for me & my car.
They also seem to last a long time too.
Old 03-04-2011, 07:39 AM
  #34
Izzone
Izzone's Avatar
Endless brake pads for me....on a 997
Flat six motor works in south Florida runs them on their 996
I swear by them for de
Old 03-04-2011, 09:00 AM
  #35
911SLOW
Admin
911SLOW's Avatar
Don't like the PCCB bias, I want more front bite.
But apparently I am in the minority.. : )
Old 03-04-2011, 09:18 AM
  #36
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
The 996 GT3 has a significant bias towards the front. I went through front rotors and pads in ten days of track using Pagid RS 19s all around. The rear rotors had no wear at all.
A change to RS 29 fronts, RS 14 (black) in the rear and adding Cup Car front brake ducts allowed me to get 40 days on the front rotors and about the same on the rears. Braking was improved as well. I have no experience with PFC, but I am convinced that using higher friction pads on the rear of the 6GT3 is essential. On the 997 GT3 and RS, PAG changed the brake bias to the extent that a higher friction pad in the rear was no longer needed. Cooling to the front rotors was also improved.
Old 03-04-2011, 11:37 AM
  #37
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
That is exactly correct, Bob.
WILD999, if youlike RS19 you will like the newer RS29 a bit better: More bite, same long wear.
Quick Reply: Let's talk brake pads
