996 GT2/GT3 Forum 1999-2005
**UPDATED (post 23) ** Another Coolant Line Failure
Old 01-28-2011, 10:48 AM
452gt3
452gt3's Avatar
The fittings in the manifolds are easily weldable by a qualified welder unless you just want to spend two hundred more bucks. They referred to 6 fittings we welded 8 in my 04.
Old 01-28-2011, 04:05 PM
FFaust
FFaust's Avatar
^ Yes, I e-mailed and asked about that. Reply was that they were only aware of six and that the kit was 3 big and 3 small, and all were straight fittings (no elbow).
Old 01-28-2011, 09:13 PM
452gt3
452gt3's Avatar
One of the fittings that failed on mine was a curved one under the power steering.
Old 01-28-2011, 09:22 PM
FFaust
FFaust's Avatar
I know, seems to be one of the really common ones.
Old 01-30-2011, 12:42 PM
himself
himself's Avatar
Figured I'd cross post this:
Originally Posted by wogamax
The NHTSA has opened investigations from more limited complaints than it seems are being volunteered about these fittings. They only respond to issues that can become safety hazards. Rapidly losing coolant on a curve, or ramp, is a concern. No?
NHTSA complaints:
https://www-odi.nhtsa.dot.gov/ivoq/online.cfm
If you own a car with the GT1 engine and it has failed this way, give them your VIN. If you won't do it for your own sake, please do it for the rest of us. Otherwise, it looks like we're just mice.
-td
Old 02-02-2011, 12:56 PM
4porsh
4porsh's Avatar
I just filled out the NHTSA complaints form.
Hope others are doing the same.
Joe
Old 02-02-2011, 01:17 PM
redridge
redridge's Avatar
-td
hell, should just cross post it on all gt/turbo boards....
Old 02-03-2011, 12:53 PM
himself
himself's Avatar
Originally Posted by FFaust
Would be nice of you to report back with what they did to fix it.
Update:
  • Coolant diaphram (bracket) for power steering pump: 996-314-091-04
  • O-ring: 999-707-298-40
  • coolant 000-043-301-05
  • labor 8.7 hours
I asked for the broken part, which is downstairs. I'll snap some pics later and post them.
-td
Old 02-03-2011, 02:39 PM
FFaust
FFaust's Avatar
Man I love RL
Thanks.
Surprisingly cheap for what they call the "bracket".
Also interesting how, some dealers replace the manifolds (bracket), and some re-glue the offending couplings. Wonder if it depends on the dealer or on which coupling let go.
Old 02-03-2011, 05:53 PM
Mikelly
Mikelly's Avatar
Mine were re-glued on my 01 turbo, right before I bought it. Haven't had issues "yet" but plan to remove the whole setup and have it all welded up.
Mike
Quick Reply: **UPDATED (post 23) ** Another Coolant Line Failure
