Insalled the 19" Wheels... Real Tight... Now What?
#46
12 is a tight fit on a 996 narrow bodied car.
As a general rule run the widest wheel you can for the size of tire you are running. I can't say I subscribe to the buy one set of wheels now while you learn the car and then buy a different set thinking. Why not just get the optimal to begin with, unless you have plans to have more than one set with track tires....
#51
GT3 player par excellence
"Super light, a local independent shop uses them for the Boxter Spec series. Lou"
which shop?
those are not spec legal.
BSR wheels MUST be equal or heavier than OEM.
which shop?
#52
The shop is called Precision Motorsports, I believe that is what they said at one of their techs. I could be mistaken... I leave it to the tech inspectors to decide... I'm happy with them on my car, the price is right, with the right offset and the sinister look...
#54
Not to confuse things further...
Here is some CCW ****...
http://site.titanmotorsports.com/blo...k/ccwc2k-1.jpg
#57
I just came across this thread, rather topical for me today. First let me introduce myself to the 996 GT3 community. I just traded my 07 997S for a 04 996 GT3. I've got 2 sets of 19" track wheels from the S which have to go. I've also got a set of CCW 18", 9" fronts and 12" rears. Don't have the offsets for them. The fronts look like they will fit fine with 245/40/18 hoosier R6's. On the rears I've currently got 335/30/18 R6's. With the rears mounted it looks like the side wall might be too close to the fender under compression. I'm hoping with 315/30/18 there will be enough clearance. The question I have is does any of you run 315's on your cars. If the 315 will fit and clear the fender, it looks like it may be tight, but with a little more camber than is on the car now it should be okay. The prior owner never tracked the car, so I'm expecting the current camber is only about -1.5.
Any thoughts would be appreciated.
Thanks, John
Thanks, John
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
#59
va122 Thanks for the input. I didn't want to have to replace the CCW's. Good wheels. Can't wait to get this baby on the track and see what it can do. March seems like a long way off.
J
J
