996 GT2/GT3 Forum 1999-2005
Rennline wheel studs, any good?
Old 12-17-2010, 04:18 PM
LVDell
LVDell's Avatar
Will do!
BTW....here are the bolt weights.
Stock bolt 3.30 ounces (93.55g)
Stock bolt for use with 5mm spacer kit 3.45 ounces (97.8g)
Rennline stud and nut 3.80 ounces of which 2.60 is the stud (107.7g/73.7g)
Old 12-17-2010, 04:30 PM
911SLOW
Admin
911SLOW's Avatar
Great info! You even included the red hat bolts.
Old 12-17-2010, 05:10 PM
LVDell
LVDell's Avatar
Crap! Just got back from the liquor store and they don't have it. Just that entry level Russian Standard. No platinum
And that's really my only place to get it since the liquor stores are state run agencies.
Old 12-17-2010, 05:19 PM
911SLOW
Admin
911SLOW's Avatar
From what I hear i think in US is easier to buy cocaine than cigarettes and drinks..
Old 12-18-2010, 12:34 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,749 Likes on 2,355 Posts
Originally Posted by 911SLOW
How heavier/lighter are the studs from oem bolts ?
my studs are of balsa wood. no wt.
Old 12-18-2010, 03:42 AM
Backmarker
Backmarker's Avatar
Originally Posted by Number54
This is for stock 996 GT3 wheels.
I don't want to pollute this forum with another "which studs" to get but search has not been helpful enough...
I read BBS does not not work. Neither does CDOC. H&R has been reported to work. Okay, but which ones? I have no clue about thread/pitch/length. And safety first, I want good ones.
Anyone tried the Rennline ones? I'm making an order from them anyway.
Thanks.
I have CDOC ones, they work with stock wheels and HREs
Old 12-18-2010, 05:24 AM
AllanJ
AllanJ's Avatar
Apex here.
Old 12-18-2010, 11:03 AM
LVDell
LVDell's Avatar
Ah, the ever rare and pricey balsa wood option
Old 12-18-2010, 02:16 PM
CT03911
CT03911's Avatar
For DE types what is the point of studs?
I am missing something here and it can't be the 1/2 oz weight savings....is it?
If it is....you guys are sicker than I ever thought :-)
I have never had enough trouble changing wheels that I felt the need to go to studs.
Enlighten me please.
Old 12-18-2010, 03:20 PM
AllanJ
AllanJ's Avatar
I change wheels a lot and I'm too lazy to use the aluminum wheel changing alignment rod all the time. I'd rather fire up the impact gun and zip, zip, zip, zip, zip all 5 nuts are off and the wheel is pulled off the car.
Old 12-18-2010, 03:22 PM
LVDell
LVDell's Avatar
What Allan says. I do enough wheel changes and brake pad and fluid changes that makes it SOOOOOOOOOOOOOOO easy to dismount and mount the wheels without ever having to worry about rotor/wheel contact. Get tiring unbolting 2 lugs bolts, screwing in two wheel hangers, do the rest, and then reverse and redo for each wheel.
Old 12-18-2010, 06:53 PM
CT03911
CT03911's Avatar
Okay, I understand. I don't use wheel hangers though and do a pretty good number of wheel changes too.
I find if I squat in front of the wheel and brace the base of it with a toe I can spin all the lugs off with a gun and then just pull off the wheel.
Same deal to put it back on.
I guess I can see where it would be a little easier with studs but I have never bothered whith wheel hangers and not had any issues.
Thanks for the info. You guys now have me thinking....
Old 12-18-2010, 07:20 PM
SH || NC
SH || NC's Avatar
+ you needn't worry about cross threading the bolt and damaging the wheel carrier (almost poka-yoke)
+ new wheels with different offsets don't require longer or shorter bolts
Old 12-18-2010, 08:13 PM
LVDell
LVDell's Avatar
Two EXCELLENT points that we failed to cover!
Strip a stud? $5 replacement. Strip the threads in the wheel carrier? $$$.
All various wheels (and spacers) work with no need to change bolts. Again, $$$.
Plus, all it takes is the wheel to fall off once and bang the inside of you wheel, chip a PCCB, damage the caliper, etc, etc, etc., and you quickly realize it's very nice to have the studs.
Old 12-18-2010, 08:19 PM
tdarby
tdarby's Avatar
i used to have them on my other car. i need them again, its the way the c ar should have been designed
Quick Reply: Rennline wheel studs, any good?
