Hoosiers
I used MPSC for track days with my '04 GT3 for years. I got 6-7 days out of them before they corded. ![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
This year I decided to try Hoosiers. My shop recommended 3.0 degrees rear and 2.5 front for them. I got only 2 days of track use before the rears corded, so they dialled it back to 2.5 in the rear.
I JUST GOT ONLY 1.5 DAYS (1 day at Monticello and .5 day at Thunderbolt.)
THIS IS RIDICULOUS.![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
In between using the MPSC and Hoosiers I ran on Toyo R888 for a while; they lasted MUCH longer, so I'm planing to use them again. Or maybe I should revert to MPSC and get my 6-7 days.
COMMENTS ANYONE/ALL ?????
THIS IS RIDICULOUS.
GT3 player par excellence
u reduced camber, i presume you corded inside then?
something is not right, chk toe.
i can't see why R6 gets corded on inside since you can't drive it on street.
i have -3 on my R6
i have -3 on my R6
As you know Fred Thunderbolt chewed up my new NTO1's too. They are not corded but the one day there took a heavy toll. I think I got about a dozen days + out of my last set of Nittos and these have 5 days and are looking close to done. I only mention this as a data point to consider before blaming the Hoosiers solely. It's a know fact that the octopus (at thunderbolt) eats tires.
COMMENTS ANYONE/ALL ?????![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
THIS IS RIDICULOUS.
More info is needed.
Fellows,
I have been wearing out the Hoosiers on the inside on the rears, and on the outside on the fronts.
QUESTION: How many days of track use do YOU get out of them on the GT3??
2. based on your wear pattern, more camber front, less camber rear
3. CHK YOUR TOE. i bet it's fk'd up.
Try kuhmo v710's they lasted 42 hc's before they corded(grip was awesome til 38hc after that felt like mpsc's) but I do rotate and flip them. Similar grip as Hoosiers. Mike
