Access To the ECU with the Teq Bar Installed?
#31
Not much progress today; I need a little help running a wire to the fuse panel for the switched power; this should happen tomorrow.
#33
Vimeo Link of Test Vid
I was happy when I saw the RPMs on the top of teh camera becasue then I knew I had tapped the correct CAN wires.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I ran the switched power from the phone plug behind the center console.
#34
Dude! you are pulling .2Gs in your garage! Nice ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Glad it worked! TPS as well. I couldn't tell if the brake light came on, but I'm sure it's working since you are on the CAN bus!
Congrats!!
-td
Congrats!!
-td
