Newbie Track / DE Chronicle!
Hi all,
Remember this post? Can't believe I have had the GT3 for almost 9 months now. The car has been great, no problem whatsoever. Just filled up the gas and go. Put almost 4,000 miles on it so far!![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Anyway, it is only natural (since I hang around the GT2/3 forum most of time) that I'm looking into driving the car on the track. (Bad influence from you guys, bad, bad!)
As mentioned before in my introductory post, I don't have any prior tracking driving experience (heck, actually have not owned a performance vehicle prior to GT3!
) so I'm literally starting at 0. So I figured that it would be kind of interesting to document the progress and lessons learned going from zero to hero. ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
So far I have signed up for 4 DEs in April and May. (I learned my lesson when I couldn't sign up for the last DE last year, as the green group sold out rather quickly)
So lesson #1, newbies, find out when the registration opens, and sign up right away!! (bookmark the website http://www.clubregistration.net!)
My first DE will be Lime Rock, 4/5/10! (So if any of you are attending, please stop by to say hi to the very slow #125.. !)
2nd DE will be the novice day at Lime Rock, 4/17/10.
Next one is New Hampshire Motor Speedway novice day, 5/7/10.
And then Monticello, 5/20-21 (2 days event).
All 4 events are w/ PCA (various regions, however)
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
For the past few months, I have been collecting parts.. trying to make the GT3 "mine".. some of the stuff so far..
Fire extinguisher w/ mount
6-Point Harness (Schroth)
HANS device
Helmet
HANS device
Helmet
If the schroth shoulders are the 3 inch wide ones it will overlap the Hans collar- either rubs your next or overlap outside of Hans. I ordered the 2/3 ones. Mike
Some more stuff..
BK harness mounting hardware
BK seat sidemounts (for Sparco seats)
BK sub bars (not pictured)
I'm still waiting for a pair of Sparco Pro 2000 seats.. not sure when they will get here..
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Mike,
Yeah, they are the 3" version.. From the research I did, I thought the 3" are okay for HANS while 2" is HANS only. (Is that not correct?) So I figured that 3" is more versatile? (I have no idea if my instructor will have HANS or not, for example..)
Can always change out the shoulder belt if that's an issue, I assume.
"My first DE will be Lime Rock, 4/5/10! (So if any of you are attending, please stop by to say hi to the very slow #125.. !)"
Sorry to hear that you already know you are going to be "very slow".
Put a Kia emblem on it and maybe no one will notice..... Just give er' hell and you will be pleased.
So it does not appear that I will have the seats in time (although ordered awhile ago) for my first DE.. no biggie.. hopefully be ready for my 2nd or 3rd.. !
Anyway, next up, take the car to get tech inspected. I made a post about this and I ended up taking it to a nearby race shop, Musante Motorsports. While there, also did an oil change and brake flush.
Some pics of the car while it is there.. ! (notice the Cup bake duct and aftermarket sway bar links from the previous owner)
Still plays with cars.
3" will work with HANS but 2 " is the ideal size for a HANS device.
Well, the slowness does not reflect badly on the car.. people will know that it is the driver... ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
But I will be willing to listen and learn.. no ego here.. we all got to start somewhere, I guess.. !!
Good luck. Do not worry about being fast or slow just listen to your instructor.
You must start/learn a base before you can get to the top of the pyramid/pointy end.
Have fun and feel the car.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Thanks! Yeah, not gonna worry about pointing by other cars.. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
It will be the first time driving on track for me and I know that I'm no Hurley Haywood.. so no worry.. !!
Did my first DIY w/ GT3 today.. changed out the air filter. I'm a believer in using OEM filter (instead of performance aftermarket unit) but change it at higher frequency. I plan to change the filter every 10,000 miles.
It was an easy job. Can be done in 20-30 minutes or so. (even for someone who have never worked on it before)
Notice the old filter is dirty.. ! However, it sure did its job. On the filtered side of the air box, it is virtually brand new with no sign of any dust at all!
My tip for the air filter change:
-> Keep an eye on the 2 rubber grommets where the airbox attaches to the chassis. Don't lose them.. !
-> Rotate the hose clamp so you can use a socket in the future. (see pic) Make it a lot easier compare to try to use a screwdriver in there.. not much room!
Are instructor's able to drive your car? U can order Hans only for driver side only. It's just not shoulder belts but lap belts as well that are 2 inch. Lap is straight 2 inch and shoulder is 2 inch then 3 inch to buckle. I know 3 inch will work but 2 inch way more comfortable- does not rub your neck and on the track u want to be comfortable. Just a thought. Mike
