Motons?
Jeff and Dave are in a different league. If they had 7 gt3's and ran it like the 6's it'll be faster for sure. Wish I had their *****. Mike
If u r in sf bay area with watervooled 911 and is not set up by Tony or JWE. Uh.... U have a so so set up.
All sharkys cars are also set up and aligned by Tony.
JUST DROP OFF THE CAR
LEAVE money
then DONE
he's got all parts figured out and has done enough gt3's. Nine gt3 for me alone and 18 porsches in total fir me. If he tells me my cars fine then IRS fine.
LEAVE money
then DONE
Just saw this post.
https://rennlist.com/forums/997-gt2-...k-version.html
Steve helped me set up my 996GT3 and the 996GT2. I really respect his opinion's and would recommend him if you don't mind traveling a little.
Peter
on hoosier with 4.0 RP and stock suspension jeff did 1:47:xx with AMB timing
not sure what tire dave was on, but he did it with stock RP but with moton at 1:49:9
i know jochen and jeff personally and they know each other as well.
jochen is very modest. maybe too much!
i dont push my RS much. can't afford to write it off.
but i did 1:53 with R888.
so with fresh hoosier and a bit of pushing i am sure i'll get to 1:51. certainly jochen is more than just 1 second faster than moi.
Victor call me stupid but what are the advantages of 3 way vs 2 way motons. Also did u start out of the box with 1000/1200 springs? Mike
2-way allows for adjustment of rebound and bump (aka compression)
3-way allows for adjustment of rebound as well as low and high speed bump
4-way allows for adjustment of low and high speed rebound as well as low and high speed bump
Now prior to getting motons what is needed to get it prepped ie monoballs etc? thanks. Now those with 2 way and seems like majority has them on would 3 way be better way to go. Victor with 3 way driving in the track what is apparent vs 2 way version. thanks. Mike
THe thing to understand about suspension components is something will ALWAYS be the weak link and be the the weak point and possible point of failure.
When I did my suspension, I thought about just doing "this" or just doing "that" and at the end of the day I decided to do it as ONE COMPLETE SYSTEM (like it is).
If you upgrade one piece to a motorsport unit, IMHO, you need to upgrade the rest.
As far as the dampers, there is a reason why the cups went BACKWARD with their shocks. MOre adjustments is leading to too much confusion and inability to properly setup the car. THere are very few people that actually know how to do this properly which is why paying for professional track support form somebody that knows this stuff can setup your car properly.
So, the question is, what's the budget?
I know I'll be happy with 2 way and from what I heard 3 way aint an easy task to set up. Budget what's that? I usually tell my wife after the fact and she goes ape**** but this time around I've been real good- she has total control of house remodel and the monies for it. But whatever I do -my main thing is mentality is get it done and forget about it- I dont want alot of headaches as my car now feels great but I want to go the next step. I've been thinking bout this for some quite sometime on my gt3 so I value everyone elses opinion here. Dell u did most of the strip yourself on the bsr rt? did u do the ac delete yourself?Mike
Easy task to do? If I had my house(hopefully July) I be doing all the stripping myself but have no time where I live. I am doing the front trunk this Sunday. I know how to remove stuff just don't ask me to put it all back : ). Mike
Now Dell with respect to radio was it an easy task to take all the wires off? Also did u remove the airbags too? If so once done can piwis disable the airbag completely
or that damn airbag lite be on 24/7.
