How much premium for CPO?
Found this thread in the 997 forum:
https://rennlist.com/forums/997-foru...-worth-it.html
Also for reference, I paid $2800 for 7/70 when I bought mine new. I was told Porsche does not offer extended warranty on new purchase so mine was thru 3rd party. A company called CNA National, I hope they are still around as I have not filed any claim yet.
I got one from "Easy Care" sold to me by my local Porsche dealership. My car was still on original warranty, which was about to expire. Cost about $2500. They have come through with needed repairs.
The dealer's cost for the CPO depends on the car. What car are you looking at?
Here is the CPO language:
ThePorsche Approved Limited Warranty offers full
peace of mind that in the unlikely event of your Porsche
developing a fault, the affected parts will be replaced or
repaired as required*** with no deductible. The warranty
coverage is limited to the following components:
• Engine: Engine block and all engine internal parts,
cylinder head(s) and valve assembly, oil cooler(s),
head gasket(s), manifolds, flywheel, chains/tensioner,
oil pan, oil pump, exhaust manifold, turbo charger,
clutch master and master and slave cylinders, and
all related engine seals and gaskets if related to
warranty repair.
•Transmission:Transmission case and differential
housing(s) and all their internal parts, clutch master
cylinder, clutch slave cylinder, torque converter, flex
plate, and all seals and gaskets.
•Drive Train: Torque tube, drive shaft assembly,
center bearing assembly, and drive axle with
constant velocity joints.
•Suspension & Steering: Steering wheel, rack and
pinion steering gear, power steering pump.
•Cooling System: Water pump, fan, thermostat,
radiator thermoswitch, and all related seals
and gaskets.
•Heating/Air Conditioning: Heater/air conditioning
regulation controls, a/c clutch, compressor,
condenser, evaporator, control unit for climate control.
•Fuel System: Fuel injectors, throttle valve housing,
air flow sensor, intake air distributor, intake manifold,
pressure regulator, temperature sensors, control
units, warm-up regulator, fuel distributor, fuel line,
air pump, and all related seals and gaskets.
•Electrical System: Fuel pump, oil temperature
sending unit, turbo charger water pump, alternator,
voltage regulator, starter, radiator fan switch,
ignition coil, ignition distributor, hall sensor, knock
sensor, distributor cap(s), rotor, ignition cables/
connectors, high beam switch, all electrical motors,
pumps, and all control units for the following factory
installed systems (if
equipped): Anti-Lock
Braking System,
supplemental restraint,
wiper/washer, intensive
headlight washer,
headlights, door lock, power
windows, rear wiper, rear
hatch release, spoiler,
cruise control, factory
alarm, Porsche Dynamic
all-wheel drive (Carrera 4),
limited slip differential (928),
tire pressure warning (928),
central information panel,
on-board computer, and
climate control.
•ABS Brake System
(if equipped): ABS wheel
sensors, control unit,
modulator, ABS
hydraulic pump.
•Supplemental Restraint
System (if equipped):
Air Bag control unit and
airbag sensor.
•Brake System: Master
cylinder, brake pressure
regulator, brake pressure
accumulator, brake booster.
Limitations.
The warranty does not cover:
•Batteries damaged
from storage
•Batteries damaged from
lack of use
•Tires damaged by
road hazard
•Tires damaged by
premature wear
•Parts that fail due to lack
of maintenance
• Normal wear and tear
• Cleaning and polishing
• Lubricants
•Air conditioner
refrigerant charge
•Glass Breakage
•Vehicles originating outside
of USA and Canada
•Unauthorized modifications
•Wheel balancing and tires
Validity.
For added convenience, your
Warranty coverage is included
in the purchase price. Since
the warranty applies to the
vehicle rather than the owner,
it remains intact and can be
transferred with the private
selling of your Porsche.
Porsche Roadside Assistance.
Your Porsche Approved vehicle
also comes with Porsche Roadside
Assistance, an exclusive support
service that offers added security
when travelling at home or abroad.
In addition to breakdown, accident,
transport and recovery, the
program includes a range of other
coverage services. Please see
your dealer for more information.
Peace of mind.
With the added security that
comes with comprehensive
warranty cover, you can now
look forwardto many thousands
of miles of even greater driving
pleasure from your Porsche.
*** Warranty Coverage: Porsche Cars North
America will repair or replace with a new part
distributed by Porsche Cars North America,
at its sole option, any factory-installed part
that is faulty in material or workmanship under
normal use. Warranty repairs will be made
free of charge for parts and labor at an
authorized Porsche dealer.
warranty repair.
and gaskets.
Braking System,
headlight washer,
climate control.
•ABS Brake System
modulator, ABS
hydraulic pump.
airbag sensor.
Limitations.
•Batteries damaged
from storage
lack of use
•Tires damaged by
road hazard
•Tires damaged by
premature wear
of maintenance
• Lubricants
•Air conditioner
refrigerant charge
•Glass Breakage
of USA and Canada
Validity.
Peace of mind.
I purchased my extended warranty at Sunset Porsche. They offered 3 levels of coverage, silver, gold and platinum. I went with the platinum for $2,600 because it basically covered most everything except wear items. Just make sure you are aware of any deductable per occurance, 75 bucks seems to be the normal.
I used it for a recent clutch job with RS parts and it worked fine. It was also used for an RMS job with no issues.
Your shop will have to do a bit of back an forth with this type of warranty, with CPO the dealer just does it all in my experience
Polly Q at Sunset can hook you up by phone, warranty works anywhere
I bought one from my local dealer and they use Fidelity Warranty Services as well. I did a little research and FWS is owned by JM Enterprises. If you don't know who JM Enterprises is, they are very well funded to say the least.
Odd that you got your clutch job warrantied, I have their top of the line warranty and the SA made it clear to me that clutch components were not covered and even showed me in the brochure.
///Michael
///Michael
